    start.g with temperature and print ranges, etc?
    Gcode meta commands
    • zuoyanundefined
      zuoyan
      Is there a way to pass temperature, material, print ranges etc from the slicer to the start.g?
      With this, we can put as much common starting part into the start.g file as possible. Otherwise, we may have to use slicer specific start part.
      • Superbrain8undefined
        Superbrain8
        start.g runs before the slicer gcode.
        running a seperate macro at the start of the print called from the slicer and passing in the values is common
        • oliofundefined
          oliof
          as superbrain said. Teamgloomy built a reference config using a start_print macro from the slicer, you can have a look at https://github.com/TeamGloomy/Troodon-V2/tree/improved/Config/sys
          zuoyanundefined 1 Reply Last reply Reply Quote 0
          • zuoyanundefined
            zuoyan @oliof
            Thanks both, this confirms my understanding and the example configuration is very helpful.
            I saw some release notes that we will have job.file.customInfo, which could already have this info. But I'm not sure it's accessible in the start.g or not -- I'd wait for a stable release to try this.
              I do a generic preheat in start.g to get the heaters warming up while the printer homes. Then the slicer takes over with final temps. Saves some time anyway.
