    Switch to limit move increments
    CNC
    • dhusoloundefined
      dhusolo
      I have a duet 3 mini running my cnc controlling DWC with my tablet. I use a digital edge finder to find 0,0 of my workspace. Occasionally while dialing in 0,0 instead of hitting .05, .5 gets hit moving the axis too far.
      I'm wondering if there's a way to use a toggle switch connected to one of the open input pins as a trigger that could override the axis movements to make sure it doesn't move over .05mm each time a move button is pressed.
        jay_s_uk @dhusolo
        @dhusolo you could try G38.2 moves instead which are protected and will stop when the probe is triggered.
        The millenniumOS plugin has it working I believe and that's aimed for CNC use. It's still a work in progress though
