    Plan to switch from normal steppers to 1HCL+ magnetic encoders
    Using Duet Controllers
    808
    • martin7404undefined
      martin7404
      I have been planning for more than a year to convert my big (600x400) ABS CoreXY printer to a closed loop.
      For this more than an year ago I got 1HCL board+ duet magnetic encoders.
      The machine is with Duet 3.
      I spent today the time to read through the documentation and came up with the following plan, and please correct me where you think I made a wrong step or missed something
      1. Based on the documentation, I will have to remove the steppers and install magnets and encoder boards on them. They have to be removed so I can perform the initial tuning of the encoder paired with the motor and magnet
      2. Install both HCL boards, connect them to the CAN in a daisy chain with the tool board I use, and connect motors and encoders also the power to both HCL boards
      3. Power them on by one and assign an address to each of them
      4. with everything wired, I have to perform tuning with M569.6
      5. To reinstall the steppers in the printer
      6. To perform PID tuning
        I know it will take some questions additionally, but for now, I have one major question
        In some older threads, I read that homing has to be performed in open-loop mode. Is that a fact?
        Additionally, these axes (X and Y ) are using sensorless. homing Is this going to work in a closed loop?
        In the past, I did set up a closed loop with duet two wifi, but it was with external drivers, and I just used an extension board to output direction, pthe ulse signal
      Thank you for any advice and comments in advance
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
      • T3P3Tonyundefined
        T3P3Tony administrators @martin7404
        @martin7404
        1. Yes that's correct. take care with the jig to ensure the magnets are centered.
          2- 5 . yes
          6 Yes, on a core XY i set one of the motors to enable with the max safe current in open loop mode (so its held in place as firmly as possible), then tune the other motor. once one motor is tuned you can then reverse the arrangement and confirm the same settings work on the other one. they are likely to be the same or very similar if the motors are the same.
        Homing;
        Yes, home in open loop mode and then switch to closed lop mode. this is straight forward to do in your homing files. If they are already working with sensor less homing in open loop mode using the same stepper driver IC (i.e. the ones on the 6HC) they they should how be able to home using sensorless homing on the 1HCLs with the same settings for stall threshold. Note stall homing on expansion boards was only implemented in the 3.6beta3 release - you have good timing!
        www.duet3d.com
        martin7404undefined 1 Reply Last reply Reply Quote 0
          martin7404 @T3P3Tony
          @T3P3Tony Thank you
          You are right about the timing. I am currently on 3.5.2 ( updated lastly because of the filament sensor on the main board feature when using tool board)
          I will first try everything on 3.5.2 by manually setting the home position and will commission the setup. If everything plays as expected, we will go through switching to 3.6 beta 3
          Your help here is one of the reasons duet ecosystem is my preferred for almost any project I do
          martin7404undefined 1 Reply Last reply Reply Quote 1
            martin7404 @martin7404
            Happy to report in open loop it works as expected with the 2 HCL board
            Homing works from the first try with 3.6 beta 3
            Did not manage to test closed loop as my motors are 60 mm and the suitable screw is 80 mm M3 , that I did have only 1 pc left in the drawer. So tomorrow evening will be able to install encoders and test
              martin7404
              FAIL of the initial tuning
              So after yestarday everythig was set in open loop and working , homing etc.
              Today I remembered I have m3 treaded rods and managed to attach the first encoder
              I unloaded the stepper ( removed the belt) and hit the wall
              here is what I get
              1/20/2025, 5:05:29 PM	M569.6 P50.0 V3
              Error: M569.6: Driver 50.0 calibration failed (no reason available)
              1/20/2025, 5:00:24 PM	M569.6 P50.0 V2
              Error: M569.6: Driver 50.0 calibration failed, the measured motion was less than expected, measured counts/step is about 41.0
              Warning: Driver 50.0 warning: tuning/calibration failed
              1/20/2025, 4:59:51 PM	m17
              1/20/2025, 4:59:29 PM	M569.6 P50.0 V2
              Error: M569.6: Driver is not enabled
              1/20/2025, 4:59:05 PM	Upload of config.g successful after 0s
              Here is my config.g
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 27 2021 13:17:12 GMT+0300 (Eastern European Summer Time)
              G90                                                    ; send absolute coordinates...
              M83                                                    ; ...but relative extruder moves
              M550 P"CoreXY500"                                     ; set printer name
              M669 K1                                                ; select CoreXY mode
              M552 P192.168.1.27 S1                                       ; enable network and acquire dynamic address via DHCP
              M586 P0 S1                                             ; enable HTTP
              M586 P1 S0                                             ; disable FTP
              M586 P2 S0                                             ; disable Telnet
              G4 S2   ;wait for expansion boards to start
              M569.1 P50.0 T3 E1:2 R100 I0 D0 ; Configure the Duet 3 Expansion 1HCL board at CAN address 50 with a Duet 3 magnetic encoder, warn if 1 fullstep threshold exceeded, error if 2 full steps threshold exceeded.
              M569 P50.0 D4 S1 ;
              ;M569 P0.0 S1                                           ; physical drive 0.0 goes forwards
              M569 P0.1 S0                                    ; physical drive 0.1 goes forwards
              M569 P0.3 S0
              M569 P0.4 S1
              M569 P0.5 S1                                           ; physical drive 0.2 goes forwards
              M569 P121.0 S1                                         ; physical drive 121.0 goes forwards
              M584 X50.0 Y0.1 Z0.3:0.4:0.5 E121.0                             ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
              M92 X160.00 Y160.00 Z8280.00 E395.70                      ; set steps per mm
              M350 X32 Y32 Z16 E16 I1
              M566 X300.00 Y300.00 Z50.00 E120.00                    ; set maximum instantaneous speed changes (mm/min)
              M203 X12000.00 Y12000.00 Z150.00 E1200.00                ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E500.00                    ; set accelerations (mm/s^2)
              M906 X1700 Y1700 Z1000 E800 I30                           ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                                ; Set idle timeout
              M208 X-26 Y0 Z0 S1                                       ; set axis minima
              M208 X500 Y330 Z365 S0                                 ; set axis maxima
              M574 X1 S4                                             ; configure sensorless endstop for low end on X
              M574 Y1 S4                                             ; configure sensorless endstop for low end on Y
              M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
              ;M574 E1 S1
              ;Filament sensor BTT E1
              M591 D0 P2 C"io8.in" S1 ;configure BTT smart filament sensor
              M671 X-31.39:250:531.36 Y-18:433.3:-18 S10       ; Locations left, center, right
              M558 P8 C"121.io2.in"  H3 F1000 T6000 A20 S0.005 ; PINDA set Z probe type to switch and the dive height + speeds
              ;M308 S2 P"121.temp1" A"PINDA" Y"thermistor" T100000 B3950
              ;M950 H2 C"out1" T2                                 ; create nozzle heater output on 121.out0 and map it to sensor 1
              ;M307 H2 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
              ;M141 H2
              ;M143 H2 S90                                           ; set temperature limit for heater 1 to 280C
              G31 P500 X30 Y0 Z1.48                            ; set Z probe trigger value, offset and trigger height
              M557 X20:450 Y5:320 P5                             ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B4138           ; configure sensor 0 as thermistor on pin temp0
              M950 H0 C"out0" T0 Q10                                     ; create bed heater output on out0 and map it to sensor 0
              M307 H0 B0 S1                                      ; disable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                                ; map heated bed to heater 0
              M143 H0 S130                                          ; set temperature limit for heater 0 to 120C
              M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8       ; configure sensor 1 as thermistor on pin 121.temp0
              M950 H1 C"121.out0" T1                                 ; create nozzle heater output on 121.out0 and map it to sensor 1
              M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
              M143 H1 S290     ; set temperature limit for heater 1 to 280C
              M308 S2 A"Chamber" P"temp2" Y"thermistor" T100000 B4725 C7.06e-8
              M950 H2 C"out2" T2                                 ; create nozzle heater output on 121.out0 and map it to sensor 1
              M307 H2 R0.001 A11 C99999 D4000 B1   ; disable bang-bang mode for heater  and set PWM limit
              M141 H2
              M143 H2 S70
              M950 F0 C"121.out1"                               ; create fan 0 on pin 121.out1 and set its frequency
              M106 P0 S0 B0.5 H-1                                         ; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"121.out2" Q500                               ; create fan 1 on pin 121.out2 and set its frequency
              M106 P1 S1 H1 T45                                      ; set fan 1 value. Thermostatic control is turned on
              M563 P0 D0 H1 F0                                       ; define tool 0
              G10 P0 X0 Y0 Z-0.15                                        ; set tool 0 axis offsets
              G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
              M955 P121.0 I05 ;Accelerometer on Toolboard
              M575 P1 S1 B57600                                      ; enable support for PanelDue
              M572 D0 S0.045 ; PA for ABS GD filament 0.4 nozzle
              M501                                                   ; load saved parameters from non-volatile memory
              M911 S22.5 R23.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
              and here are diagnostics right after the error
              system
              	m122
              RepRapFirmware for Duet 3 MB6HC version 3.6.0-beta.3 (2025-01-16 19:09:36) running on Duet 3 MB6HC v1.01 (standalone mode)
              Board ID: 08DJM-9P63L-DJMSS-6JKDA-3S86L-1BDB9
              Used output buffers: 1 of 40 (21 max)
              Static ram: 136892
              Dynamic ram: 127588 of which 16 recycled
              Never used RAM 79560, free system stack 200 words
              Tasks: NETWORK(1,ready,28.2%,175) ETHERNET(5,nWait 7,0.1%,316) HEAT(3,nWait 6,0.0%,347) Move(4,nWait 6,0.0%,333) TMC(4,nWait 6,3.1%,375) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,350) MAIN(1,running,68.5%,103) IDLE(0,ready,0.0%,29) USBD(3,blocked,0.0%,149), total 100.0%
              Owned mutexes:
              Last reset 00:14:48 ago, cause: software
              Last software reset at 2025-01-20 16:59, reason: User, Gcodes spinning, available RAM 78828, slot 2
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 25.3, current 26.1, max 26.3
              Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
              Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
              Events: 1 queued, 1 completed
              Date/time: 2025-01-20 17:13:57
              Slowest loop: 3.22ms; fastest: 0.07ms
              USB interrupts 2
              === Storage ===
              Free file entries: 20
              SD card 0 detected, interface speed: 25.0MBytes/sec
              SD card longest read time 1.0ms, write time 0.0ms, max retries 0
              Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
              Pos req/act/dcf: 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00
              next step interrupt due in 9 ticks, disabled
              Driver 0: standstill, SG min n/a, mspos 8, reads 7783, writes 11 timeouts 0
              Driver 1: standstill, SG min n/a, mspos 4, reads 7773, writes 21 timeouts 0
              Driver 2: standstill, SG min n/a, mspos 8, reads 7783, writes 11 timeouts 0
              Driver 3: standstill, SG min n/a, mspos 8, reads 7773, writes 21 timeouts 0
              Driver 4: standstill, SG min n/a, mspos 8, reads 7773, writes 21 timeouts 0
              Driver 5: standstill, SG min n/a, mspos 8, reads 7773, writes 21 timeouts 0
              Phase step loop runtime (us): min=0, max=89, frequency (Hz): min=1666, max=2500
              === DDARing 0 ===
              Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
              Segments left 0, axes/extruders owned 0x00000000, drives owned 0x00000000
              Code queue is empty
              === DDARing 1 ===
              Code queue is empty
              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1 -1 -1 -1 -1, ordering err=== GCodes ===
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              File2 is idle in state(s) 0
              Queue2 is idle in state(s) 0
              === Filament sensors ===
              check 0 clear 6854308
              Extruder 0 sensor: ok
              === CAN ===
              Messages queued 7938, received 25025, lost 0, ignored 0, errs 0, boc 0
              Longest wait 13ms for reply type 6018, peak Tx sync delay 376, free buffers 50 (min 49), ts 4213/4212/0
              Tx timeouts 0,0,0,0,0,0
              === Network ===
              Slowest loop: 3.10ms; fastest: 0.03ms
              Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
              HTTP sessions: 2 of 8
              = Ethernet =
              Interface state: active
              Error counts: 0 0 0 1 0 0
              Socket states: 6 2 2 2 2 0 0 0 0
              === Multicast handler ===
              Responder is inactive, messages received 0, responses 0
              for the 1hcl board attached with the encoder
              m122 b50
              Diagnostics for board 50:
              Duet EXP1HCL rev 1.0a or earlier firmware version 3.6.0-beta.3 (2025-01-15 18:54:31)
              Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
              All averaging filters OK
              Never used RAM 51588, free system stack 182 words
              Tasks: EncCal(1,nWait 6,0.0%,312) Move(3,nWait 7,0.0%,167) CLSend(3,nWait 6,0.0%,149) TMC(4,nWait 6,60.5%,317) HEAT(2,nWait 6,0.0%,105) CanAsync(5,nWait 4,0.0%,66) CanRecv(3,nWait 1,0.0%,65) CanClock(5,nWait 1,0.0%,64) MAIN(1,running,38.4%,315) IDLE(0,ready,0.1%,29) AIN(2,nWait 2,1.0%,255), total 100.0%
              Owned mutexes:
              Last reset 00:15:41 ago, cause: software
              Last software reset data not available
              Moves scheduled 0, hiccups 0 (0.00/0.00ms), segs 0, step errors 0 (types 0x0), maxLate 0 maxPrep 0, ebfmin 0.00 max 0.00
              Phase step loop runtime (us): min=26, max=65, frequency (Hz): min=8720, max=18292
              Peak sync jitter -7/9, peak Rx sync delay 187, resyncs 0/0, next timer interrupt due in 11 ticks, enabled, next step interrupt due in 3589150588 ticks, disabled
              VIN voltage: min 24.2, current 24.3, max 24.3
              V12 voltage: min 12.0, current 12.0, max 12.1
              MCU temperature: min 28.2C, current 29.1C, mDriver 0: pos -1080, 320.0 steps/mm, not tuned/calibrated, tuning/calibration failed, SG min n/a, mspos 4, reads 21334, writes 21 timeouts 0
              Last sensors broadcast 0x00000000 found 0 181 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 7704, send timeouts 0, received 12134, lost 0, ignored 0, errs 0, boc 0, free buffers 38, min 38, error reg 0
              dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
              Closed loop driver 0 mode: closed loop, pre-error threshold: 1.00, error threshold: 2.00, encoder type rotaryAS5047, position 5520
              Encoder reverse polarity: no, full rotations 0, last angle 5523, minCorrection=0.0, maxCorrection=0.0, agc 87, mag 4700, no error
              Tuning mode: 0, tuning error: 0x6, collecting data: no
              Accelerometer: none
              I2C bus errors 12, naks 0, contentions 0, other errors 0
              Any help is very much appreciated
                martin7404
                Just in case downgraded back to 3.5.4 and the result is the same
                  martin7404
                  I am stupid these are 0.9 mottors
                  tried to edit M569.1 with S400 parameter and the calibration went well , but after that the motor entered in such big resonance in stoped position , that crashed the whole board
                  1/20/2025, 8:37:55 PM	Connection established
                  1/20/2025, 8:37:25 PM	Connection interrupted, attempting to reconnect...
                  Network error: Request timed out
                  1/20/2025, 8:37:17 PM	Warning: Driver 50.0 warning: position tolerance exceeded
                  1/20/2025, 8:37:16 PM	m17
                  1/20/2025, 8:36:28 PM	Warning: Driver 50.0 warning: position tolerance exceeded
                  1/20/2025, 8:36:27 PM	Connection established
                  1/20/2025, 8:36:12 PM	Connection interrupted, attempting to reconnect...
                  1/20/2025, 8:36:03 PM	m569.6 p50.0 v2
                  Driver 50.0 calibration succeeded, measured backlash is -0.084 step
                  Original encoder reading errors: min -12.3, max 14.8, rms 5.2
                  Corrections made: min -9.0, max 10.0, rms 5.1
                  1/20/2025, 8:35:37 PM	m569.6 p50.0
                  1/20/2025, 8:35:14 PM	m569.1 p50.0
                  Encoder type: rotaryAS5047
                  Magnetic encoder motor steps/rev 400, agc 80, mag 4715
                  PID parameters P=100.0 I=0.000 D=0.000 V=1000.0 A=0.0, torque constant 1.00Nm/A
                  Warning/error threshold 1.00/2.00
                  1/20/2025, 8:35:03 PM	m17
                  1/20/2025, 8:34:47 PM	Upload of config.g successful after 0s
                  1/20/2025, 6:39:33 PM	Connection established
                    jay_s_uk @martin7404
                    @martin7404 grab an M122 and M122 B50 so we can see whats the cause of the reboot
                    martin7404undefined 2 Replies Last reply Reply Quote 0
                      martin7404 @jay_s_uk
                      @jay_s_uk Reboot is fixed I uped the error in m596.1
                      It now just gives a warning when I send m17
                      if I reset the tuning 569.6 p50.0 v4 it goes away
                      so the problem seems to be 0.9 steppers
                      it performs calibration and after that goes in resonance
                        @jay_s_uk here is new calibration
                        and then the m122 p50.0
                        m122 b50
                        Never used RAM 51588, free system stack 184 words
                        Tasks: EncCal(1,nWait 6,0.3%,183) Move(3,nWait 7,0.0%,167) CLSend(3,nWait 6,0.0%,149) TMC(4,nWait 6,66.5%,317) HEAT(2,nWait 6,0.1%,105) CanAsync(5,nWait 4,0.0%,66) CanRecv(3,nWait 1,0.0%,65) CanClock(5,nWait 1,0.0%,64) MAIN(1,running,32.0%,253) IDLE(0,ready,0.0%,29) AIN(2,nWait 2,1.2%,255), total 100.0%
                        Owned mutexes:
                        Last reset 00:05:44 ago, cause: software
                        Phase step loop runtime (us): min=26, max=65, frequency (Hz): min=4807, max=18292
                        Peak sync jitter -7/7, peak Rx sync delay 190, resyncs 0/0, next timer interrupt due in 2 ticks, enabled, next step interrupt due in 4036578614 ticks, disabled
                        MCU temperature: min 28.4C, current 29.1C, maDriver 0: pos 690, 320.0 steps/mm, position tolerance exceeded, failed to maintain position, SG min n/a, mspos 4, reads 25157, writes 8 timeouts 0
                        Last sensors broadcast 0x00000000 found 0 89 ticks ago, 0 ordering errs, loop time 0
                        CAN messages queued 2421, send timeouts 0, received 3688, lost 0, ignored 0, errs 0, boc 0, free buffers 38, min 38, error reg 0
                        Closed loop driver 0 mode: closed loop, pre-error threshold: 10.00, error threshold: 20.00, encoder type rotaryAS5047, position -1966
                        Encoder reverse polarity: no, full rotations -1, last angle 14418, minCorrection=-9.0, maxCorrection=9.2, agc 79, mag 4747, no error
                        Tuning mode: 0, tuning error: 0, collecting data: no
                        Accelerometer: none
                        I2C bus errors 0, naks 0, contentions 0, other errors 0
                          martin7404
                          I think I found the culprit.
                          Originally due to heavy gantry my motors LDO-42STH60-MAC were runing at 1700 mA max current cutoff (2 Amps max)
                          I reduced the current to 1200 mA and now it is without vibrations in closed loop mode
                           1/20/2025, 10:05:28 PM	m569.6 p50.0 v3
                          Driver 50.0 calibration check succeeded, measured backlash is -0.067 step
                          Residual encoder reading errors: min -5.0, max 11.3, rms 1.4
                          1/20/2025, 10:04:47 PM	m569.6 p50.0 v2
                          Driver 50.0 calibration succeeded, measured backlash is -0.074 step
                          Original encoder reading errors: min -13.8, max 14.1, rms 5.7
                          Corrections made: min -9.6, max 9.2, rms 5.6
                          1/20/2025, 10:04:11 PM	m17
                          1/20/2025, 10:04:05 PM	M906 X1200 Y1200 I0
                          I still do not know if these numbers are good
                            dc42 administrators @martin7404
                            @martin7404 that backlash number is good and the other readings looks OK to me. It's more difficult to get good readings using 0.9deg motors than it is using 1.8 deg motors which is what we recommend.
                            If you want to increase the motor current beyond 1200mA without getting instability, try reducing the PID P parameter in the M569.1 command from its default value.
                              martin7404 @dc42
                              @dc42 Does that mean 0.9 steppers will have problems running in closed loop ?
                                @martin7404 they should run OK, however the speed won't be as high as you can get using 1.8deg motors and the tuning will be more critical. With a closed loop motor it's the encoder that determines the resolution, not the motor.
                                  martin7404 @dc42
                                  @dc42 Thank you . I get this but these are on the machine. Any guidelines about PID tuning. I managed to make it today following the wiki guide and my graphs are more "noisy" is this to be expected. It is a big machine with 0.6 and 0.8revo nozzles. But I limit the acceleration a lot , hopin to improve this by going closed loop
                                    martin7404
                                    @dc42 Something to ask
                                    When you do manual tuning with the plugin after it is finished.
                                    How to save the tuned parameters?
                                    Do I need to enter them in config.g in the 569.1 command?
                                      @martin7404 yes you need to put the new parameters in the M569.1 command in config.g.
                                        martin7404 @dc42
                                        @dc42 does this manual tooling look OK?
                                        This is what I cma up after following the tuning guide
                                          this is the second motor
                                            martin7404
                                            the final config.g
                                            M569.1 P50.0 T3 E4:8 S400 R40 I1500 D0.05 V400 A200000 H10 ; Configure the Duet 3 Expansion 1HCL board at CAN address 50 with a Duet 3 magnetic encoder, warn if 1 fullstep threshold exceeded, error if 2 full steps threshold exceeded.
                                            M569 P50.0 D4 S1 ;
                                            ;M569 P0.1 S0                                    ; physical drive 0.1 goes forwards
                                            M569.1 P51.0 T3 E4:8 S400 R40 I1500 D0.05 V400 A200000 H10 ; Configure the Duet 3 Expansion 1HCL board at CAN address 50 with a Duet 3 magnetic encoder, warn if 1 fullstep threshold exceeded, error if 2 full steps threshold exceeded.
                                            M569 P51.0 D4 S0
                                            M569 P0.3 S0
                                            M569 P0.4 S1
                                            M584 X50.0 Y51.0 Z0.3:0.4:0.5 E121.0                             ; set drive mapping
                                            ;M350 X32 Y32 Z16 E16 I1
                                            M201 X1000.00 Y1000.00 Z20.00 E500.00                    ; set accelerations (mm/s^2)
                                            M906 Z1000 E800 I30                           ; set motor currents (mA) and motor idle factor in per cent
                                            M906 X1700 Y1700 I30
                                            ;M574 E1 S1
                                            ;M141 H2
                                            M141 H2
                                            M143 H2 S70
