Can’t connect to printer after ssid and password change
Hi I was able to print from my Mac over WiFi using ender 3 local, before we had to change our router. I have gone on the sd card and changed the ssid name and password but I still cannot connect and I cannot seen the printer on my network
@jedi you're best off connecting over USB to the board and sending the correct wifi commands that way.
you can also see what the printer thinks is going on -
@jay_s_uk hi jay thanks, I think you helped me last time when I lost all my firmware and you sorted it by taking control of my computer. I have tried connecting to the printer by wire but I couldn’t get that to work either
@jedi here's a page about it on the wiki https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-2-connect-your-duet-via-usb
the fun is getting a micro USB cable that you know is a data one and not just charging -
@jay_s_uk yea you showed me which one to buy last time it’s just the programming stuff I struggle with
@jedi well get the connection going as detailed there and then send
M122
andM552
and post the outputs here
