    [3.6.0-beta.3] DWC connection issues Duet2 / Duex5
    Beta Firmware
    922
    • timschneiderundefined
      timschneider
      Hi Duet3d,
      the connection wasn't rock solid since the switch to WIFISocketServerRTOS but it was getting better over time. After upgrading to 3.6.0-beta.3 there are again connection losses. It is easiest to reproduce with an M122 - just repeat the command in the console until it gets stuck and DWC will reconnect. Sometimes it takes just one M122, sometimes it needs a few consecutive requests. Anyhow the same connection drop will also occour sometimes on file uploads, while printing or using DWC. It looks like, it is not effecting RRF, as there is no restart or exception, it will just reset all open sessions and they need to reconnect.
      Output of M122
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-beta.3 (2025-01-16 19:09:12) running on Duet WiFi 1.02 or later + DueX5v0.11
      Board ID: 08DJM-9178L-L4MSJ-6J1FL-3S86J-TB2LN
      Used output buffers: 3 of 26 (26 max)
      Static ram: 23520
      Dynamic ram: 70940 of which 12 recycled
      Never used RAM 16980, free system stack 108 words
      Tasks: LASER(5,nWait 6,0.0%,214) NETWORK(1,ready,14.1%,181) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,266) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,85.2%,689) IDLE(0,ready,0.6%,29), total 100.0%
      Owned mutexes:
      Last reset 05:20:42 ago, cause: power up
      Last software reset at 2025-01-22 17:09, reason: User, Gcodes spinning, available RAM 16628, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x04
      MCU temperature: min 31.0, current 31.4, max 32.6
      Supply voltage: min 23.8, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/380/220, gc cycles 895
      Events: 1 queued, 1 completed
      Date/time: 2025-01-23 15:27:10
      Slowest loop: 13.79ms; fastest: 0.21ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 9.3ms, write time 2.8ms, max retries 0
      Segments created 356, maxWait 0ms, bed comp in use: mesh, height map offset -0.009, hiccups added 0/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
      Pos req/act/dcf: 99920.00/99920/0.00 35280.00/35280/0.00 157593.00/157593/-1.00
      no step interrupt scheduled
      Driver 0: standstill, SG min n/a
      Driven n/a
      Driver 4: standstill, SG min n/a
      Driver 5: standstill, SG min n/a
      Driver 6: standsr 1: standstill, SG min n/a
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min n/a
      Driver 6: standstill, SG min n/a
      Driver 7: standstill, SG min n/a
      Driver 8: standstill, SG min n/a
      Driver 9: standstill, SG min n/a
      Driver 10:
      Driver 11:
      === DDARing 0 ===
      Scheduled moves 153592, completed 153592, LaErrors 0, Underruns [0, 0, 0]
      Segments left 0
      Code queue is empty
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.2
      Movement locks held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      === Filament sensors ===
      check 25695622 clear 40978094
      Extruder 0: pos 2403.98, errs: frame 1 parity 0 ovrun 34 pol 0 ovdue 0
      === DueX ===
      Read count 0, 0.00 reads/min
      === Network ===
      Slowest loop: 22.34ms; fastest: 0.07ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 3 of 8
      === WiFi ===
      Interface state: active
      Firmware version 2.2.1
      MAC address bc:dd:c2:31:9a:40
      Module reset reason: Turned on by main processor, Vcc 3.45, flash size 4194304, free heap 42500
      WiFi IP address 10.42.0.2
      Signal strength -17dBm, channel 1
      Output of M122 after reconnect
      M122
      Static ram: 23520
      Tasks: LASER(5,nWait 6,0.0%,214) NETWORK(1,ready,13.9%,181) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,266) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,85.4%,689) IDLE(0,ready,0.6%,29), total 100.0%
      Owned mutexes:
      Last reset 05:21:48 ago, cause: power up
      Error status: 0x04
      MCU temperature: min 31.0, current 31.3, max 31.7
      Supply voltage: min 23.8, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/860/700, gc cycles 898
      Date/time: 2025-01-23 15:28:16
      Slowest loop: 9.76ms; fastest: 0.21ms
      === Storage ===
      SD card longest read time 2.2ms, write time 0.8ms, max retries 0
      Driver 1: standstill, SG min n/a
      Driver 10:
      Driver 11:
      === DDARing 0 ===
      Segments left 0
      Code queue is empty
      check 25695622 clear 41201439
      === DueX ===
      === Network ===
      Slowest loop: 22.18ms; fastest: 0.09ms
      HTTP sessions: 2 of 8
      === WiFi ===
      Module reset reason: Turned on by main processor, Vcc 3.45, flash size 4194304, free heap 41804
      Signal strength -15dBm, channel 11, mode 802.11n, reconnections 0
      Clock register 00002002
      Socket states: 5 3 3 3 0 0 0 0
      From the Inspection view inside the browser
      don't get confused by the ip 127.0.0.1:8088 - I just tunneld the connection via putty to get direct access from the access point to the duet.
      droftartsundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @timschneider
        @timschneider Do you have a PanelDue connected? If so, what firmware version? See https://forum.duet3d.com/post/349749
        timschneiderundefined 2 Replies Last reply Reply Quote 0
          timschneider @droftarts
          @droftarts
          hi, I do not have a panel due connected.
          It's just a Duet2 Wifi and a Duex5 connected via ribbon cable and a Raspberry serving the access point, where the duet2 is connected to.
            @droftarts
            maybe it is related, as the M122 is not timed out, its rather the rr_model request. Maybe the M122 is causing a delay due to the duex5 subquery in the rr_model response.
            timschneiderundefined 1 Reply Last reply Reply Quote 0
              timschneider @timschneider
              can you give me a hint what I can do to track this error down?
              I'm able to reproduce it within seconds.
              Thanks
              Tim
              DaveAundefined droftartsundefined 2 Replies Last reply Reply Quote 0
              • DaveAundefined
                DaveA @timschneider
                @timschneider
                Is it possible you have a variation of my problem which has been solver?
                https://forum.duet3d.com/topic/37329/3-6-0-beta-3-duet-2-issues-lost-communication/3
                  @timschneider I've updated my Mini 5+ to WiFi firmware v2.2.1, which is the beta.3 release, and tried the same test, but I don't get a disconnect. I hit M122 repeatedly 22 times. It seems like I only got 18 responses, but may be I'd hit return before the M122 had returned fully. I also tested with the WiFi firmware v2.2.0 (in the 3.5.4 release), and that was fine.
                  Can you revert the WiFi firmware to v2.2.0 and see if still causes the same problem?
                  @DaveA May possibly be related, but yours was specific to the Duet 2 Ethernet, this is WiFi. But then I don't write firmware!
                    @droftarts
                    thank you for your tests!
                    I was able to hook up via USB and grab some debug logs.
                    It is somehow related to the connection mangement and kind of ran out of buffer, even if it appears that the buffers are wasted.
                    HTTP req, command words { GET /rr_model HTTP/1.0 }, parameters { key= flags=fd99 }<\n>
                    New conn on socket 2 for local port 80<\n>
                    HTTP connection accepted<\n>
                    Found responder<\n>
                    Received 287 bytes<\n>
                    New conn on socket 3 for local port 80<\n>
                    Ran out of output buffers at ../src/Networking/HttpResponder.cpp(1109)<\n>
                    Found responder<\n>
                    New conn on socket 0 for local port 80<\n>
                    Found responder<\n>
                    Received 302 bytes<\n>
                    New conn on socket 1 for local port 80<\n>
                    Found responder<\n>
                    Received 288 bytes<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.0 }, parameters { key=job flags=d5 }<\n>
                    Found responder<\n>
                    Received 419 bytes<\n>
                    Sending reply, file = no<\n>
                    HTTP req, command words { GET /rr_reply HTTP/1.0 }, parameters { }<\n>
                    Sending G-Code reply to HTTP client 1 of 2 (length 3324)<\n>
                    Found responder<\n>
                    Received 431 bytes<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.0 }, parameters { flags=d99fn }<\n>
                    Found responder<\n>
                    Found responder<\n>
                    Found responder<\n>
                    Received 445 bytes<\n>
                    HTTP req, command words { GET /rr_gcode HTTP/1.0 }, parameters { gcode=M122 }<\n>
                    Sending JSON reply, length 12<\n>
                    Found responder<\n>
                    Found responder<\n>
                    Found responder<\n>
                    Found responder<\n>
                    Peer disconnected on socket 2<\n>
                    Found responder<\n>
                    Timed out gcodeReply, free buffers=1<\n>
                    Timed out gcodeReply, free buffers=2<\n>
                    Timed out gcodeReply, free buffers=3<\n>
                    Timed out gcodeReply, free buffers=5<\n>
                    Timed out gcodeReply, free buffers=7<\n>
                    Timed out gcodeReply, free buffers=9<\n>
                    Timed out gcodeReply, free buffers=11<\n>
                    Timed out gcodeReply, free buffers=12<\n>
                    Timed out gcodeReply, free buffers=13<\n>
                    Released gcodeReply, free buffers=26<\n>
                    Peer disconnected on socket 1<\n>
                    Peer disconnected on socket 0<\n>
                    Found responder<\n>
                    Received 309 bytes<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.0 }, parameters { key=sensors.filamentMonitors flags=d4 }<\n>
                    Webserver: rejecting message with: 401 Not authorized<\n>
                    Found responder<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.0 }, parameters { key=move.compensation flags=d4 }<\n>
                    Found responder<\n>
                    Full logs attached
                    output_2025-01-27_14-41-50.txt output_2025-01-27_14-26-22.txt output_2025-01-27_14-16-17.txt output_2025-01-27_14-14-06.txt output_2025-01-27_14-12-58.txt
                      @droftarts
                      it is on both WiFi Versions - just checked v2.2.0
                      HTTP req, command words { GET /rr_gcode HTTP/1.0 }, parameters { gcode=m122 }<\n>
                      Found responder<\n>
                      Found responder<\n>
                      Received 308 bytes<\n>
                      Found responder<\n>
                      Received 442 bytes<\n>
                      Found responder<\n>
                      Received 458 bytes<\n>
                      full log
                      output_2025-01-27_14-56-34.txt
                        @timschneider Great, thanks, I'll poke @dc42 with this info.
                        • chrishammundefined
                          chrishamm administrators @timschneider
                          @timschneider What HTTP clients do you have connected and do you have a PanelDue attached, too? It looks like the G-code reply (e.g. for M122) queues up because at least one client does not request it in regular intervals.
                          Duet software engineer
                            timschneider @chrishamm
                            @chrishamm ah good catch.
                            in the logs above I've one DWC and sometimes more, upto 6 DWCs from the same machine via browser and one python client querying the object model.
                            is this client supposed to query rr_reply even if it is not asking for? all clients (should) use propper session keys.
                            the upto 6 DWCs just to poke the out of buffer and check if it makes a difference.
                            To be clear, either 1 DWC and python client or 6 DWC and 1 python clients.
                            EDIT: no panel due / standalone mode
                            EDIT 2:
                            rr_reply
                            Retrieve the last G-code reply. The G-code reply is buffered per connected HTTP client and it is discarded when every HTTP client has fetched it or when the firmware is short on memory and the client has not requested it within reasonable time (1 second).
                              @timschneider Yes, for the time being I suggest you request rr_reply as well. AFAIR G-code replies are saved up to 8 seconds. We need to discuss how connections from "bots" could be handled better, perhaps an extra key for rr_connect could be added to indicate that the new client does not wish to poll G-code replies.
                                @chrishamm
                                ok, checked it and indeed reducing the clients to one DWC session helped to mitigate the problem - or to say I was not able to trigger it via DWC with repeating M122 gcodes. But, i took the chance to rush down the rabbit hole and was able to trigger it with M122 M122 M122 as one command.
                                Found responder<\n>
                                Received 466 bytes<\n>
                                HTTP req, command words { GET /rr_gcode HTTP/1.0 }, parameters { gcode=M122 M122 M122 M122 }<\n>
                                Found responder<\n>
                                Found responder<\n>
                                Found responder<\n>
                                Found responder<\n>
                                HTTP req, command words { GET /rr_connect HTTP/1.0 }, parameters { password=meltingplot time=2025-1-27T15:33:25 sessionKey=yes }<\n>
                                Sending JSON reply, length 94<\n>
                                Found responder<\n>
                                { GET /rr_gcode HTTP/1.0 }, parameters { gcode=m122 }Bad recv status sizeError: failed to retrieve WiFi status message: another SPI transfer is pendingBad recv status sizeBad recv status sizeError: failed to retrieve WiFi status message: another SPI transfer is pendingBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeError: failed to retrieve WiFi status message: SPI timeoutBad recv status sizeReleased gcodeReply, free buffers=26Error: failed to retrieve WiFi status message: SPI timeoutBad recv status size
                                don't know if this is somehow related, just catched it as a by-catch.
                                OK, lesson learned - teach the bot to query rr_reply every second, just in case. But still there is some problem with memory management and error handling.
                                timschneiderundefined 1 Reply Last reply Reply Quote 2
                                  @chrishamm @droftarts
                                  it was to early - it will crash even with only 2 DWC connections opened. I also tried to poll rr_reply ever second but even that is not enough. If you have bad luck and two DWC sessions open, it will crash on the first or second try.
                                  EDIT:
                                  same for
                                  M409 K"" F"d2"
                                    @timschneider Thanks for the report. I've logged this at https://github.com/Duet3D/RepRapFirmware/issues/1073
                                    chrishamm created this issue in Duet3D/RepRapFirmware
                                    closed [Bug]: Long G-code replies can crash WiFi boards in standalone mode #1073
                                    timschneiderundefined 1 Reply Last reply Reply Quote 1
                                      @droftarts
                                      @chrishamm thank you for open up a bug report for it, but i'm almost certain that this is just one bug out of at least two.
                                      somehow the rr_reply can add up and even a quit short and simple output can crash the webserver / frontend.
                                      the following output shows the output in the console when at least two clients are connected, in this case two DWC sessions
                                      after adding up, it will kill all open sessions
                                      if only one DWC session is open the output looks like the following and it is impossible (via DWC) to add up the output
                                      We use a reverse proxy to connect to duet and I observed the above mentioned behavior in the past, but alwas thought it is related to the reverse proxy and was not paying attention to it. The above shown screenshots are NOT connected to the reverse proxy - I was directly connected to the duet.
                                      EDIT: I've checked if i'm able to add up the output in DSF setup or crash the frontend - and it was not possible.
                                      chrishammundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                        @timschneider DSF has a lot more memory available so it's very unlikely to get it to crash. If long G-code replies are not released quickly enough in standalone mode, that can lead to output buffer starvation which makes the whole webserver unresponsive (for a few seconds at least). That's why I proposed to call rr_reply relatively frequently from "bot" clients. The other issue which had to do with failed SPI transfers is being investigated.
                                          @chrishamm This explanation does not seem to explain the behaviour shown above.
                                          In the above example there are only two DWC sessions open and the overall output is just about 1100 characters.
                                          I did another test with the following macros:
                                          M98 P"0:/macros/test-bufferoverflow.g"
                                          echo "123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890"
                                          M98 P"0:/macros/test-bufferoverflow2.g" -> two times the content of test-bufferoverflow.g (6 times echo with 210 chars)
                                          M98 P"0:/macros/test-bufferoverflow3.g" -> two times the content of test-bufferoverflow2.g (12 times echo with 210 chars)
                                          M98 P"0:/macros/test-bufferoverflow4.g" -> two times the content of test-bufferoverflow3.g (24 times echo with 210 chars)
                                          Executing macro M98 P"0:/macros/test-bufferoverflow4.g" will work
                                          Executing two times macro M98 P"0:/macros/test-bufferoverflow4.g" will fail
                                          Executing two times macro M98 P"0:/macros/test-bufferoverflow3.g" will fail
                                          Executing two times macro M98 P"0:/macros/test-bufferoverflow2.g" will sometimes fail
                                          Executing three times macro M98 P"0:/macros/test-bufferoverflow2.g" will fail
                                          so it looks like it is realted to the memory, but it is no "out of memory" due to the size of the output.
                                          with only one DWC session i'm able to get it crashing with two times M98 P"0:/macros/test-bufferoverflow4.g" - but not with the other macros.
                                          The problem from my side is, that when two clients are connected and issue a G-Code with response, this sometimes crashes the webserver and both DWC connections are reconnecting. From theorie it should work as long as there are output buffers, but somehow it appears they get wasted somewhere.
                                          Output of M122
                                          30.1.2025, 18:36:37 	M122
                                          Used output buffers: 2 of 26 (26 max)
                                          Static ram: 23520
                                          Dynamic ram: 68716 of which 220 recycled
                                          Never used RAM 27540, free system stack 182 words
                                          Tasks: NETWORK(1,ready,16.6%,195) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,361) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,82.8%,712) IDLE(0,ready,0.5%,29), total 100.0%
                                          Owned mutexes:
                                          Last reset 30:48:46 ago, cause: power up
                                          Last software reset at 2025-01-27 15:25, reason: User, Gcodes spinning, available RAM 28108, slot 2
                                          Error status: 0x0c
                                          MCU temperature: min 28.7, current 29.2, max 30.3
                                          Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/1484/1348, gc cycles 5713
                                          Events: 0 queued, 0 completed
                                          Date/time: 2025-01-30 18:36:30
                                          Slowest loop: 17.84ms; fastest: 0.18ms
                                          === Storage ===
                                          Free file entries: 8
                                          SD card longest read time 8.5ms, write time 0.0ms, max retries 0
                                          Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
                                          Pos req/act/dcf: 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00
                                          Driver 10:
                                          Driver 11:
                                          === DDARing 0 ===
                                          Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
                                          Segments left 0
                                          Code queue is empty
                                          Daemon is doing "G4 P100" in state(s) 0 0, running macro
                                          check 0 clear 399166717
                                          Extruder 0: pos 2160.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                                          === DueX ===
                                          === Network ===
                                          Slowest loop: 21.90ms; fastest: 0.07ms
                                          HTTP sessions: 1 of 8
                                          === WiFi ===
                                          Module reset reason: Turned on by main processor, Vcc 3.46, flash size 4194304, free heap 42496
                                          Signal strength -21dBm, channel 11, mode 802.11n, reconnections 0
                                            dc42 administrators @timschneider
                                            @timschneider if you enable all Move debugging in recent versions of RRF then huge amounts of debug output are generated, which means all bets are off. M111 should only be used to enable debugging selectively, using the P and D parameters so select the modules and subsystems to debug.
                                            Duet 2 is somewhat memory constrained so it has less output buffer memory available than Duet 3 boards. That said, it does appear from the output you have posted that there may be a particular issue with the interface to the WiFi module when there is a lot of data to output. This is on my list to investigate.
