    3.6.0-beta.3+1 halted mid print
    Beta Firmware
    • kozmobotundefined
      kozmobot
      Duet 2 WiFi/Ethernet version 3.6.0-beta.3+1
      I want to report a step timing error mid print:
      Error: Movement halted because a step timing error occurred on drive 2 (code 2). Please reset the controller.
      Error: Extra info=-0.00781250
      • T3P3Tonyundefined
        T3P3Tony administrators @kozmobot
        @kozmobot thanks for reporting that. Can you update to 3.6beta3+2 and see if it occurs again and these is extra reporting in that.
        https://www.dropbox.com/scl/fo/qfbfahaqybkdbsomweh3y/AOvPK9QzWWQZ4OCVwByASWk?rlkey=r2rqkt2xire46r5brvmeurkx6&dl=0.
        www.duet3d.com
        kozmobotundefined 1 Reply Last reply Reply Quote 0
        • kozmobotundefined
          kozmobot @T3P3Tony
          @T3P3Tony thanks, I'll test
          • T3P3Tonyundefined
            @kozmobot updated 3.5beta3+3 here:
            https://www.dropbox.com/scl/fo/6kzcptwlzxyxvqrhzerpr/APNj3xtVrWJTRWzfOfN_3w8?rlkey=jprfnwuz0n3fqt3q68erpo536&dl=0
            www.duet3d.com
            DaveAundefined 1 Reply Last reply Reply Quote 0
            • DaveAundefined
              DaveA @T3P3Tony
              @T3P3Tony I updated to the most recent +3 and on my first print it failed with a message on the console.
              Error: Code 2 move error: info=-0.00195, seg: s=2467229762 t=11130 d=-29.00 u=-3.1414e-3 a=9.6290e-8 f=09
              M122 included
              console (1).txt
              Edited to add a second attempt to print:
              Error: Code 2 move error: info=-0.00195, seg: s=2255125801 t=11176 d=-25.00 u=-2.6995e-3 a=8.2784e-8 f=08
              Edited to add that I reverted back to 3.60beta3+1 and the Code 2 errors have gone away.
              T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • T3P3Tonyundefined
                T3P3Tony administrators @DaveA
                @DaveA thanks for the report. I will flag it to @dc4.
                www.duet3d.com
                  dc42 administrators @DaveA
                  @DaveA thanks for your report. I've added it to https://github.com/Duet3D/RepRapFirmware/issues/1071. We intend to resolve this in 3.6.0-rc.1.
                  dc42 created this issue in Duet3D/RepRapFirmware
                  closed Code 2 halts reported using 3.6.0-beta.2 #1071
