    [3.6.0-beta.3] Duet 3 MB6HC + Rpi3B+ CPU Overloaded?
    Beta Firmware
    • fractalengineerundefined
      fractalengineer
      Hi again,
      Just had a print stop for the title reason; I've run a M122 directly after; any ideas on what happened?
      2/3/2025, 6:28:14 PM	M122
      RepRapFirmware for Duet 3 MB6HC version 3.6.0-beta.3 (2025-01-16 19:09:36) running on Duet 3 MB6HC v1.0 or earlier (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6JTDA-3SS6L-1B76H
      Used output buffers: 1 of 40 (17 max)
      Static ram: 136892
      Dynamic ram: 96688 of which 4528 recycled
      Never used RAM 104556, free system stack 122 words
      Tasks: SBC(2,ready,0.8%,791) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,0.3%,213) TMC(4,nWait 6,3.1%,341) CanReceiv(6,nWait 1,0.0%,768) CanSender(5,nWait 7,0.0%,325) CanClock(7,delaying,0.0%,348) MAIN(2,running,95.7%,101) IDLE(0,ready,0.0%,29) USBD(3,blocked,0.0%,149), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 24:01:45 ago, cause: power up
      Last software reset at 2025-01-21 01:41, reason: User, Gcodes spinning, available RAM 105956, slot 2
      Software reset code 0x2003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      MCU temperature: min 33.7, current 35.5, max 38.2
      Supply voltage: min 29.3, current 29.5, max 29.6, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Heap OK, handles allocated/used 99/14, heap memory allocated/used/recyclable 2048/944/744, gc cycles 180
      Events: 0 queued, 0 completed
      Date/time: 2025-02-03 18:27:44
      Slowest loop: 2999.62ms; fastest: 0.05ms
      USB interrupts 2
      === Storage ===
      Free file entries: 20
      Segments created 58, maxWait 53088303ms, bed comp in use: mesh, height map offset 0.012, hiccups added 0/0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
      Pos req/act/dcf: 169688.00/169688/0.05 -4579.00/-4578/-0.99 500.00/500/0.00
      next step interrupt due in 247 ticks, disabled
      Driver 0: standstill, SG min 0, mspos 142, reads 61385, writes 304 timeouts 22
      Driver 1: standstill, SG min 0, mspos 870, reads 61385, writes 304 timeouts 22
      Driver 2: standstill, SG min 0, mspos 152, reads 61386, writes 303 timeouts 22
      Driver 3: standstill, SG min 0, mspos 200, reads 61386, writes 303 timeouts 22
      Driver 4: standstill, SG min 0, mspos 920, reads 61386, writes 303 timeouts 22
      Driver 5: standstill, SG min n/a, mspos 8, reads 61436, writes 253 timeouts 22
      Phase step loop runtime (us): min=0, max=108, frequency (Hz): min=317, max=10416
      === DDARing 0 ===
      Scheduled moves 7842, completed 7842, LaErrors 0, Underruns [0, 0, 0]
      Segments left 0, axes/extruders owned 0x80000007, drives owned 0x80000007
      Code queue is empty
      === DDARing 1 ===
      Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
      Segments left 0, axes/extruders owned 0x00000000, drives owned 0x00000000
      Code queue is empty
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1 -1 -1 -1 -1, ordering er=== GCodes ===
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      === CAN ===
      Messages queued 1835964, received 1730364, lost 0, ignored 0, errs 612, boc 0
      Longest wait 2ms for reply type 6031, peak Tx sync delay 32145, free buffers 50 (min 48), ts 409981/409980/0
      Tx timeouts 0,0,0,0,0,0
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 1
      RX/TX seq numbers: 47836/1297
      SPI underruns 0, overruns 0
      State: 5, disconnects: 13, timeouts: 13 total, 13 by SBC, IAP RAM available 0x27c70
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server version 3.6.0-beta.3 (2025-01-17 10:25:30, 64-bit)
      HTTP+Executed:
      > Executing M122
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 2
      Full transfers per second: 39.19, max time between full transfers: 17903.1ms, max pin wait times: 866.3ms/92.0ms
      Codes per second: 7.92
      Maximum length of RX/TX data transfers: 4584/1648
      2/3/2025, 6:27:34 PM	Warning: SPI connection has been reset
      2/3/2025, 6:27:34 PM	Connection to Duet established
      2/3/2025, 6:27:34 PM	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      2/3/2025, 6:27:33 PM	Warning: Did not get enough CPU time during SPI transfer, your SBC may be overloaded
      Railcore II ZL
      • chrishammundefined
        chrishamm administrators @fractalengineer
        @fractalengineer said in [3.6.0-beta.3] Duet 3 MB6HC + Rpi3B+ CPU Overloaded?:
        That doesn't look right. What kind of microSD card are you using? Can you run vcgencmd get_throttled on the SBC (e.g. via SSH or terminal) and confirm that it outputs 0x0? Something on your SBC slows down things too much for DSF to operate normally.
        Duet software engineer
        fractalengineerundefined 1 Reply Last reply Reply Quote 0
          fractalengineer @chrishamm
          @chrishamm nop no throttling of any kind. Using one of them Transcend 64G high endurance; no more than 6 months old too barely made any time
          I just run an apt update/upgrade; will see how it does
          Railcore II ZL
          • T3P3Tonyundefined
            T3P3Tony administrators @fractalengineer
            @fractalengineer are you running any other processes on the Pi other than DSF / standard DuetPi build?
            www.duet3d.com
              fractalengineer @T3P3Tony
              @T3P3Tony nothing; just dwc and vnc.
              Just had the issue occur again on beta 4 in the middle of a print:
              3/1/2025, 7:40:17 AM	M122
              RepRapFirmware for Duet 3 MB6HC version 3.6.0-beta.4 (2025-02-11 09:51:22) running on Duet 3 MB6HC v1.0 or earlier (SBC mode)
              Static ram: 137396
              Dynamic ram: 96696 of which 4584 recycled
              Never used RAM 104276, free system stack 122 words
              Tasks: SBC(2,nWait 7,1.0%,821) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,0.3%,213) TMC(4,nWait 6,3.1%,341) CanReceiv(6,nWait 1,0.0%,770) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,348) MAIN(1,running,95.5%,101) IDLE(0,ready,0.0%,29) USBD(3,blocked,0.0%,149), total 100.0%
              Last reset 08:12:26 ago, cause: software
              Last software reset at 2025-02-28 23:27, reason: User, Gcodes spinning, available RAM 105452, slot 1
              === Storage ===
              Segments created 46, maxWait 5262568ms, bed comp in use: mesh, height map offset 0.012, hiccups added 0/0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
              Pos req/act/dcf: 176745.00/176745/-0.00 -11348.00/-11348/0.00 3844.00/3844/0.00
              Next step interrupt due in 95 ticks, disabled
              Driver 0: standstill, SG min 0, mspos 362, reads 43384, writes 926 timeouts 86
              Driver 1: standstill, SG min 0, mspos 390, reads 43384, writes 926 timeouts 86
              Driver 2: standstill, SG min 0, mspos 8, reads 43385, writes 925 timeouts 86
              Driver 3: standstill, SG min 0, mspos 440, reads 43385, writes 925 timeouts 86
              Driver 4: standstill, SG min 0, mspos 920, reads 43386, writes 925 timeouts 86
              Driver 5: standstill, SG min n/a, mspos 8, reads 43420, writes 891 timeouts 86
              Phase step loop runtime (us): min=0, max=114, frequency (Hz): min=499, max=25862
              === DDARing 0 ===
              Scheduled moves 231128, completed 231128, LaErrors 0, Underruns [0, 0, 0]
              Code queue is empty
              === DDARing 1 ===
              Code queue is empty
              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1 -1 -1 -1 -1, ordering errs 0
              === CAN ===
              Messages queued 662406, received 591115, lost 0, ignored 0, errs 394, boc 0
              Longest wait 2ms for reply type 6031, peak Tx sync delay 61516, free buffers 50 (min 48), ts 140031/140030/0
              Transfer state: 5, failed transfers: 0, checksum errors: 0
              RX/TX seq numbers: 42751/30458
              State: 5, disconnects: 4, timeouts: 4 total, 4 by SBC, IAP RAM available 0x27a80
              Duet Control Server version 3.6.0-beta.4 (2025-02-11 12:05:38, 64-bit)
              HTTP+Executed:
              > Executing M122
              Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
              Full transfers per second: 39.17, max time between full transfers: 37925.2ms, max pin wait times: 1022.3ms/24.1ms
              Codes per second: 17.07
              Maximum length of RX/TX data transfers: 4580/1448
              3/1/2025, 7:26:13 AM	Warning: SPI connection has been reset
              3/1/2025, 7:25:14 AM	Warning: SPI connection has been reset
              3/1/2025, 7:24:01 AM	Warning: SPI connection has been reset
              3/1/2025, 7:23:53 AM	Warning: SPI connection has been reset
              I've also checked /var/log/syslog and here's the content:
              Mar  1 00:00:04 duet3 syslogd (GNU inetutils 2.4): restart
              Mar  1 00:20:15 duet3 -- MARK --
              Mar  1 00:40:15 duet3 -- MARK --
              Mar  1 01:00:15 duet3 -- MARK --
              Mar  1 01:20:15 duet3 -- MARK --
              Mar  1 01:40:15 duet3 -- MARK --
              Mar  1 02:00:15 duet3 -- MARK --
              Mar  1 02:20:15 duet3 -- MARK --
              Mar  1 02:20:40 duet3 vmunix: [10856.820231] kauditd_printk_skb: 11 callbacks suppressed
              Mar  1 02:20:40 duet3 vmunix: [10856.820256] audit: type=1400 audit(1740766840.671:23): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/opt/dsf/plugins/ObjectCancel/**" pid=86601 comm="apparmor_parser"
              Mar  1 02:40:15 duet3 -- MARK --
              Mar  1 03:00:15 duet3 -- MARK --
              Mar  1 03:20:15 duet3 -- MARK --
              Mar  1 03:40:15 duet3 -- MARK --
              Mar  1 04:00:15 duet3 -- MARK --
              Mar  1 04:20:15 duet3 -- MARK --
              Mar  1 04:40:15 duet3 -- MARK --
              Mar  1 05:00:15 duet3 -- MARK --
              Mar  1 05:20:15 duet3 -- MARK --
              Mar  1 05:40:15 duet3 -- MARK --
              Mar  1 06:00:15 duet3 -- MARK --
              Mar  1 06:20:15 duet3 -- MARK --
              Mar  1 06:40:15 duet3 -- MARK --
              Mar  1 06:54:22 duet3 vmunix: [27278.606049] mmc1: Controller never released inhibit bit(s).
              Mar  1 06:54:22 duet3 vmunix: [27278.606391] brcmfmac: brcmf_sdio_read_control: read 2048 control bytes failed: -5
              Mar  1 06:54:22 duet3 vmunix: [27278.606412] brcmfmac: brcmf_sdio_rxfail: abort command, terminate frame, send NAK
              Mar  1 07:20:15 duet3 -- MARK --
              Railcore II ZL
              • T3P3Tonyundefined
                @fractalengineer as a test please try a fresh DuetPi bookworm build on the SD card on the pi. Don't modify it other than to setup your printer.
                www.duet3d.com
