    Cooling fan number in Orca slicer
    • Inlinebrotherundefined
      Inlinebrother
      Hi, my problem is that Cooling fan is not working in Orca
      One way to fix that is to change my fan #0 to cooling fan. But where is fun in that?)
      Cura has this param cooling fan number. Is there a way to change cooling fan number in Orca?
        Inlinebrother
        I found this post in issues on Orca slicer github https://github.com/SoftFever/OrcaSlicer/discussions/3878
        It says that you can override it somehow. But people there are talking about klipper. I wonder if I can do the same in RRF
          Inlinebrother
          I guess it was my mistake
          I used F0 in M563 command, but should've used F3
