    31 Temp compensation
    Documentation
    • jltxundefined
      jltx
      In the documentation for G31 it says the temperature coefficient is mm/°C, which makes sense because thermal expansion is typically linear. But the formula example shows temperature squared: 1.2 + 0.02x6x6 = 1.92mm. This is for the single coefficient setting. Can someone clarify?
      • droftartsundefined droftarts moved this topic from Tuning and tweaking
        droftarts administrators @jltx
        @jltx Thanks, fixed!
        For example, G31 Z1.2 T0.02 S20 H2 when sensor 2 measures 26C would calculate trigger height as 1.2 + 0.02x6 = 1.32mm
        • droftartsundefined droftarts marked this topic as a question
        • droftartsundefined droftarts has marked this topic as solved
