Y motor seems to be stuttering.
I have been playing around trying to get each axis to home properly. I finally got the X axis working but the Y axis stutters while moving. I will try to attach a video. Any help or ideas would be greatly appreciated. Link to video is at the bottom.
This is my homey.g file
; homey.g
; called to home the Y axis
; generated by RepRapFirmware Configuration Tool on Sat Dec 30 2017 19:42:42 GMT-0700 (Mountain Standard Time)
G91 ; relative positioning
G1 Z5 F6000 ; lift Z relative to current position
G1 S1 Y-255 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F1800 ; go back a few mm
G1 S1 Y-255 F360 ; move slowly to Y axis endstop once more (second pass)
G1 Z-5 F1800 ; lower Z again
G90 ; absolute positioningand here is my homeall.g file
; Configuration file for Duet WiFi (firmware version 1.17)
; generated by RepRapFirmware Configuration Tool on Sat Mar 04 2017 15:46:00 GMT+0100 (W. Europe Standard Time); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
M208 X400 Y250 Z300 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
M558 P4 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to modulated, the axes for which it is used and the probe + travel speeds
G31 X-43 Y0 Z0 P50 ; Set Z probe trigger value, offset and trigger height
;Z-offset (Z0.9). Higher value LOWER nozzle height
; Lower value RAISE nozzle heightM557 X15:400 Y15:250 S68 ; Define mesh grid
M307 H3 A-1 C-1 D-1 ; disable heater 3, which makes it available for use to control the BLTouch; Drives
M584 X0 Y1 Z2 E3
M569 P0 S1 ; Drive 0 goes forwards - X
M569 P1 S1 ; Drive 1 goes backwards - Y
M569 P2 S0 ; Drive 2 goes backwards - Z
M569 P3 S0 ; Drive 3 goes forwards - ExtruderM350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation 16
M92 X160 Y160 Z1600 E800 ; Set steps per mm 16
M566 X600 Y600 Z12 E120 ; Set maximum instantaneous speed changes (mm/min) - (JERK)
M203 X6000 Y6000 Z500 E400 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E250 ; Set accelerations (mm/s^2)
M204 P1000 T1000 ; Set Max acceleration for P=printing moves and T=travel moves
M906 X1600 Y1600 Z900 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PBlack Widow ; Set machine name
M552 S1 ; Enable network
M587 S"RCMP Surveillance" P"241428433" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
Here is the link for the video: https://youtu.be/r1LtBLIYYqg
