I am modding takeoff toolhead to add SZP probe and currently my design is this. Fan bottom part will be SLM Aluminum, from nozzle to SZP coil pcb bottom will be 1.7mm. My main consern is the placement of SZP control board. Will it survive???
I can't tell very much from your diagram because I can't see how far the SZP control board is from the hot end. If in doubt, put a layer of glass fibre tape or similar thermal insulation behind the control board to shield it from the heat.
