Duet WiFi Connectivity Problems
I'm using a Duet 3 for WiFi connectivity to my 3D potter clay printer. I have it set up to connect to a local network instead of broadcasting its own network and this runs alright except it seems to only stay connected to the network for about a week at a time before dropping off and no longer being discoverable upon sweeping the WiFi. I have it set to a static IP, so have tried connecting to the IP anyway, but the connection times out. It is possible that there is 2.88 Ghz interference from some other devices in the vicinity, but I would assume that the Duet would be able to re-connect to the network following a brief drop. Is there some reason that getting knocked off the network would cause the Duet to be unable to reconnect? Or is there likely some other issue occurring here? Any insight would be greatly appreciated.
Can you send M122 via the gcode console when connect to DWC and share the results here?
