    Ender 3 pro
    • Hotchef54undefined
      Hotchef54
      Hi, i have the Ender 3 pro, Connected to an duet 2 wifi (V3.5.1) DWC (V3.5.1)
      my problem is the homing, the home all butten dont home to endstop switch, the config tool dont have a printer specific config setup anymore, do someone have the setup for ender 3 pro for v 3.5.1?
      i am stuck
      chrishammundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators @Hotchef54
        @Hotchef54 First of all, I suggest you upgrade to 3.5.4. We don't support outdated firmware versions.
        You can find an in-depth guide for an Ender 3 conversion to the Duet 3 Mini 5+ here, which isn't too different from the Duet 2: https://docs.duet3d.com/en/How_to_guides/e3p_Mini5+_guide_part1_wiring
        Also, you can use the legacy version of the configtool if you really need the template for the Ender 3 Pro: https://configtool.reprapfirmware.org/legacy/Start It's quite likely you need to make changes to the default tempate, though.
        Duet software engineer
          droftarts administrators @Hotchef54
          @Hotchef54 post your current config.g and homeall.g. There's example configuration files here (though running older firmware version on a Maestro rather than a Duet 2 WiFi): https://github.com/Duet3D/RRF-machine-config-files/tree/master/Ender3Pro/x0r-Maestro-RRF3
            There's also a set of guides going from initial connection to commissioning.
            https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
