Safari/Chrome cannot reach DWC anymore
Hi everyone,
I'm using a Duet3 mini 5+ wifi in SBC with a Raspberry Pi.
Everything was going well until this morning while turning on the printer as I used to. I cannot reach the DWC anymore. I tried with different browsers (Safari and Chrome). When ping the IP address I used to connect to through the terminal, it says
Request timeout for icmp_seq 1 92 bytes from 10.243.96.1: Destination Host Unreachable Vr HL TOS Len ID Flg off TTL Pro cks Src Dst 4 5 00 5400 9aa1 0 0000 3f 01 4309 10.243.110.59 10.243.25.222
Nothing changed but It does not work anymore.
What should I do to troubleshoot this?Thank you for your help.
UPDATE: For some reason, I checked the IP of the Raspberry and it changed. This is the reason why I could not connect using the old address.
Any idea why it changed?
@Timothee-Leblond If you have the RPi IP address set by the router DHCP, rather than having a static IP address, it's your router than changed it.
You should also be able to connect via the machine name, eg 'Duet3.local'. See https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#a-note-about-mdns-local-network-discovery
