    Changing Z-Offset Calibration Steps
    • Leo-Danielundefined
      Leo-Daniel
      I have been calibrated my machine before and the options for the z-offset calibrations had been plus-minus, 0.02, 0.5, 1, 25, and 50. Recently while recalibrating the smallest step (0.02) changed to 0.05 and my 1 step changed to 5. Is there a way I can manually adjust these numbers?
      Thanks for any help!
      • fcwiltundefined
        fcwilt
        In the DWC you can right-click on one of the existing "jog" values for any axis and it will popup a dialog asking for a new value.
        Leo-Danielundefined 1 Reply Last reply Reply Quote 2
          Leo-Daniel @fcwilt
          @fcwilt It worked. Thank you so much!!
