Endstop wiring is functional, but not detected by Duet
Having an issue with my endstops on a Duet 3 MB6HC (new board purchased recently). I have switch-type endstops, normally closed. I wired them between the GND and IN pins of io0-2. Using a multimeter, I can confirm that the switches are indeed working, wiring-wise. Duet cannot read them at all. M119 tells me two of them are triggered, but none of them are - when I do actually close them, M119 has no change. There is no indicator on the dashboard either, nor does homing work.
Relevant config (The actual file has dots in it for the pin names, but the forum won't let me post that since this is a new account and it thinks it's a link):; Endstops
M574 X2 P"io2in" S1 ; configure X axis endstop
M574 Y1 P"io1in" S1 ; configure Y axis endstop
M574 Z2 P"io0in" S1 ; configure Z axis endstopM119 output:
Endstops - X: at max stop, Y: at min stop, Z: not stopped, Z probe: at min stopM115 output:
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.5.4 ELECTRONICS: Duet 3 MB6HC v1.02b or later FIRMWARE_DATE: 2024-11-24 10:47:10Any help appreciated, thank you in advance. This configuration has worked for me before so I am at odds as to why it isn't right now.
@fcwilt Yes, I have written them like that in the real config file. This is a new account and the forum thinks that is a website link, so I could not send the post with that.
@nsgarde I've upvoted you, so you should be able to post now. It's to stop spammers posting links.
I'd guess you have the endstops plugged in incorrectly, as two of them (X and Y) are saying they are at the endstop, and one of them (Z) isn't. Assuming the axes are all touching, or not touching, the endstops, I would expect them to either all be on (at max/min), or all off (not stopped). Double check you have wired the correct endstop to the correct IO header on the Duet. Post a picture of the wiring if in doubt.
