    duetBackup Plugin
    Plugins for DWC and DSF
    1
    • stuartofmtundefined
      stuartofmt
      This plugin provides periodic or instant backups of duet3d SBC files. Backups are made to a Github repository, thereby facilitating the ability to roll back to earlier file versions.
      Instructions and plugins for V3.5 and V3.6 can be found here
      https://github.com/stuartofmt/duetBackup
      V1.0
      • Initial release
      V1.1
      • Error messages sent to DWC
      • Displays time to next backup using local time (previously GMT)
      • Added -duetPassword to support for printers that use a password
      • Added -verbose to enable more detailed log messages.
      V1.2
      • Added -noDelete option
      • Compares files to determine if an update is needed.
      • Added date / time of last change to file (except initial save).
      V1.3
      • README.md file shows date and time of last backup
      • README.md prevented from being deleted
      • Added -ignore. Can specify files that are not to be backed up. This also causes these files to be deleted unless -noDelete is set.
      V1.4
      • README.md file now shows a summary of the last backup i.e. files added, updated, deleted.
      • Added a logfile accessible from DWC
      • updated deprecated calls Requires Python > 3.8
      V1.5
      • updated python packages to allow newer versions
      • fixed a non-critical error in shutdown
      • enforced mandatory options
      • fixed error when -ignore was not provided
      • fixed issue handling multiple -ignore
      Installation instructions and code can be found here:
      stuartofmtundefined 1 Reply Last reply Reply Quote 2
        stuartofmt @stuartofmt
        Just released V1.4
        It is available for both DWC3.5 and DWC3.6
        Note that this plugin backs up its associated printer to Github (which retains versions). For backing up to a file system - take a look at
        https://forum.duet3d.com/topic/10880/rfm-reprapfirmware-filemanager-duetbackup-successor
        If there is sufficient interest - I can look at creating a non-plugin version that can backup a standalone printer (i.e. non SBC) from a remote computer.
        Let me know.
        • stuartofmtundefined stuartofmt marked this topic as a regular topic
          V1.5 released
