Scanning Z Axis Probe Issue
I originally had the Z axis probe outputting garbage values to the mainboard 6HC but now it stopped working and it only reads 0. I have attached the config file.
My setup is: I have a Mainboard 6HC connected to a Revo Roto TDB on which is a scanning Z axis SZP probe.
; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.10 on Sun Jan 19 2025 10:10:54 GMT-0800 (Pacific Standard Time) ; General G90 ; absolute coordinates M83 ; relative extruder moves M550 P"5axis" ; set hostname G4 S2 ; Smart Drivers M569 P70.0 S0 R1; driver 0.0 goes forwards (X axis) M569.1 P70.0 T3 R100 I0 M569 P70.0 D4 ;M569 P71.0 S1 D2 ; driver 0.1 goes forwards (Y axis) M569 P71.0 S0 R1; driver 0.0 goes forwards (X axis) M569.1 P71.0 T3 R100 I0 M569 P71.0 D4 ;M569 P72.0 S1 D2 ; driver 0.2 goes forwards (Z axis) M569 P72.0 S0 R1; driver 0.0 goes forwards (X axis) M569.1 P72.0 T3 R100 I0 M569 P72.0 D4 ;M569 P73.0 S1 D2 ; driver 0.4 goes forwards (U axis) M569 P73.0 S0 R1; driver 0.0 goes forward s (X axis) M569.1 P73.0 T3 R100 I0 M569 P73.0 D4 ;M569 P74.0 S1 D2 ; driver 0.5 goes forwards (V axis) M569 P74.0 S0 R1; driver 0.0 goes forwards (X axis) M569.1 P74.0 T3 R100 I0 M569 P74.0 D4 ; Axes M584 X70.0 Y71.0 Z72.0 U73.0 V74.0 E75.0 ; set axis mapping M350 X16 Y16 Z16 U16 V16 I1 ; configure microstepping with interpolation M92 X640 Y640 Z1969.230 U800 V27.350 ; configure steps per mm M906 X1500 Y1500 Z1500 U1500 V1500 ; set axis driver currents M208 X0:1000 Y0:820 Z0:210 U-20:100 V-999:999 ; set minimum and maximum axis limits M566 X500 Y500 Z500 U500 V1000 ; set maximum instantaneous speed changes (mm/min) M203 X1500 Y1500 Z500 U500 V2000 ; set maximum speeds (mm/min) M201 X500 Y500 Z500 U500 V1000 ; set accelerations (mm/s^2) ; Kinematics ;M669 K8 ; configure CoreXYUV kinematics ; Endstops M574 X1 P"!io3.in" S1 ; configure X axis endstop M574 Y1 P"!io0.in" S1 ; configure Y axis endstop M574 Z2 P"!io7.in" S1 ; configure Z axis endstop M574 U0 ; configure U axis endstop M574 V0 ; configure V axis endstop G92 V0 ; set V axis to zero upon startup G92 U0 ; set V axis to zero upon startup ; Extruder M350 E16 I1 ; configure microstepping with interpolation M906 E900 ; set extruder driver currents M92 E2682 ; configure steps per mm M566 E120 ; set maximum instantaneous speed changes (mm/min) M203 E3600 ; set maximum speeds (mm/min) M201 E250 ; set accelerations (mm/s^2) ;Nozzle Temperature M308 S1 P"75.temp1" Y"thermistor" A"Nozzle" T100000 B4267 C7.06e-8 ; configure sensor #1 M950 H1 C"75.out0" T1 ; create heater #1 hotend heater M143 H1 P0 S275 A0 M143 H1 P1 S285 A2 M307 H1 R4.663 K0.549:0.000 D1.95 E1.35 S1.00 B0 ; Scanning Z Probe M558 P11 C"75.i2c.ldc1612" F36000 T36000 M308 A"SZP coil" S10 Y"thermistor" P"75.temp2" ; thermistor on coil G31 Z2 X302 Y245 ; M558.2 K0 S13 R142607 M557 X292:312 Y235:255 P10 ; M558.1 K0 A-3.798e-4 B-2.723e-9 C3.136e-15 -
@ash100 if it read zero, that suggests that the connection between the coil and the control board is broken.
@dc42 I tried a different probe, checked the continuity connection on the ribbon cable, and tried a different ribbon cable as well, it didn't change anything. I believe this device stopped working only when I was working on trying to setup a 2D mesh scan.
@ash100 I suggest you get a diagnostic report on the tool board by sending
M122 B75
and post the result here.
