    Echo command syntax
    DSF Development
    • Gamefanatic3Dundefined
      Gamefanatic3D
      I was working with the echo syntax to incorporate the ">" & ">>" capabilities and was using the persistentGlobal.g file identified in the "GCode Meta Commands. However, when executing the file I receive the error:
      Error: in file macro line 6 column 7: meta command: expected a string expression
      file: _TestVar1
      M98 P"/sys/scripts/persistentGlobal.g" V"testVar" X"one"
      After some back-and-forth, I found the root cause to be that the example had a space the ">" Removing the space resolved the problem. I only noticed this after looking at the earlier examples in the documentation which did not have the additional space where the filename was being provided.
      Old code:
      var id = param.V                    ; name of the global variable
      var value = param.X                 ; value to save
      var filepath = "globals/"^{var.id}  ; internal file path where the global variable is saved
      ; Save the global variable as a file so it is persistent
      echo > {var.filepath} "if exists(global."^{var.id}^")"
      echo >> {var.filepath} "    set global."^{var.id}^" = "^{var.value}
      echo >> {var.filepath} "else"
      echo >> {var.filepath} "    global "^{var.id}^" = "^{var.value}
      M98 P{var.filepath} ; load the global variable
      Working code:
      echo >{var.filepath} "if exists(global."^{var.id}^")"
      echo >>{var.filepath} "    set global."^{var.id}^" = "^{var.value}
      echo >>{var.filepath} "else"
      echo >>{var.filepath} "    global "^{var.id}^" = "^{var.value}
      I just thought I'd pass this along.
      Using v3.6 rc1 & rc2 both produced the error.
      gloomyandyundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @Gamefanatic3D
        @Gamefanatic3D Are you running in standalone mode or using an SBC?
        Gamefanatic3Dundefined 1 Reply Last reply Reply Quote 0
          Gamefanatic3D @gloomyandy
          @gloomyandy Stand-alone mode.
            dc42 administrators @Gamefanatic3D
            @Gamefanatic3D that's correct, the syntax described at https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#echo-command does not permit spaces after the > or >> or >>> symbol.
            Gamefanatic3Dundefined 1 Reply Last reply Reply Quote 1
              Gamefanatic3D @dc42
              @dc42 Tracking the syntax. However with the example at the bottom of the page not following the syntax it's not clear, so I thought it worth reporting such that either the "Examples of Use" section or the syntax would be updated.
              Saving and restoring variables across a reset
              • persistentGlobal.g
              • loadPersistentGlobal.g
                @Gamefanatic3D thanks, I have corrected the persistentGlobal.g example.
