Bug on 3.6.0? Layershifts & stuttering on arc travel moves
@CaiJonas said in Bug on 3.6.0? Layershifts & stuttering on arc travel moves:
I changed one other setting in the slicer --> resolution down to 0,025. This should result in shorter segments? I don't know.
Yes, I'd think that creates smaller segments. If you can get it to create arc moves for the travel moves, that would probably help.
The M122 reports still say
max steps late 1
, but that might be a limit rather than the number of late steps. I'll check with @dc42.For the M595 P parameter, it takes up extra memory as you increase it. If you increase it too much, you'll get a memory warning. You can check how much free RAM you have in the M122 report. Adding more to your config will increase the memory usage, too.
