Some general questions for setup
this is my first post so I would like to introduce my project. After starting with an Anet A8 I decided to build my own (cartesian) printer and selected the Duet 3D WiFi for controlling. Most important parts are already builtup and now I want to finalize the important details.
In this context I have some questions where you hopefully can help me
For z-axis I would like to use two endstops: One at start which is also used for auto bed leveling and the other at the other side. Is it possible to define two endstops for one axis?
When using two motors besides the (shared) connector for Z: Is the by M906 selected current for each motor or combined for both?
I am using glass bed and a piezo for triggering. So for bed compensation Mesh compensation is not really needed. Isn't there a possibility to use a linear compensation? With only some measure points mesh will cause some oscillation in interpolated bed surface? What are your recommendations?
Best regards
Holger -
Welcome to the forum!
Although it's possible to use 2 Z endstop switches by temporarily creating an additional axis in the homing files, it's easier to use just one and to do side to side levelling using the Z probe to adjust the motors individually. See https://duet3d.com/wiki/Bed_levelling_using_multiple_independent_Z_motors.
The current set by M906 is per motor.
You can use mesh levelling with just 4 points near the corners of the bed.
thanks for your answers! Regarding the 2nd Z endstop I would like to use it as a safety enhancement, which should also work while printing or other activities. So - there I would have to use a mechanical barrier for this?
Best regards
Holger -
Depending on the leadscrew pitch/lead you use, perhaps motor stall detection would be suitable?
If you do want to use multiple Z endstops, see https://www.duet3d.com/forum/thread.php?pid=10946#p10946 and subsequent posts in that thread.
