    More heater for a tool in copy mode
    MultiAxis Printing
    • CorvoConVundefined
      CorvoConV
      Good morning.
      I'm designing and building a printer with four tools in a dual IDEX configuration. I've created a new gcode to enable and disable copy mode, but I get an error if I assign more than two heaters.
      ;Configurador del modo copia M940 Cx
      if(param.C == 1)
          M563 P4 S"Copia cuadruple" D0:1:2:3 H1:2:3:4 X0:3 Y1:4 F0:2:4:6
          G10 P4 X0 Y0 U{-(move.axes[3].max/2)} V{-(move.axes[4].max/2)} S0 R0
          M567 P4 E1:1:1:1
      if(param.C == 0)
          T0 P0
          M563 P4 D-1 H-1
      Is there any way to be able to manage all 4 heaters at the same time?
      Thanks
        droftarts administrators @CorvoConV
        @CorvoConV What hardware and firmware are you using? Send M122 and post the response.
        Presumably you're using a Duet 3 Mini 5+. Currently the limit for the Mini 5+ is 2 heaters per tool, see https://docs.duet3d.com/User_manual/RepRapFirmware/RepRapFirmware_overview#firmware-configuration-limits
        @dc42 may be able to increase this; I'm not sure why it's only 2 compared to other boards.
        CorvoConVundefined 1 Reply Last reply Reply Quote 0
          CorvoConV @droftarts
          @droftarts
          Yes, i am using the wifi mini, i forget to see that limit 😓😓
          I will manually set the temperatures in the starting gcode of the slicer.
          Thanks.
          M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.6.0-rc.2 (2025-03-31 12:16:33) running on Duet 3 Mini5plus WiFi (standalone mode)
          Board ID: UGZBM-7M9MK-K65J0-40TKW-MTW2Z-ZHTW6
          Used output buffers: 2 of 40 (32 max)
          Static ram: 94764
          Dynamic ram: 98336 of which 404 recycled
          Never used RAM 47964, free system stack 186 words
          Tasks: NETWORK(1,ready,15.9%,193) LASER(5,nWait 7,0.0%,235) HEAT(3,nWait 6,0.0%,325) Move(4,nWait 6,0.0%,339) TMC(4,nWait 6,1.4%,99) CanReceiv(6,nWait 1,0.2%,771) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) MAIN(1,running,81.7%,647) IDLE(0,ready,0.0%,29) USBD(3,blocked,0.0%,133) AIN(4,delaying,0.8%,261), total 100.0%
          Owned mutexes:
          Last reset 03:54:03 ago, cause: software
          Last software reset at 2025-04-29 12:57, reason: User, Gcodes spinning, available RAM 46292, slot 2
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          === Storage ===
          Free file entries: 19
          SD card longest read time 31.6ms, write time 0.8ms, max retries 0
          Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
          Pos req/act/dcf: 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00
          No step interrupt scheduled
          Driver 0: standstill, SG min 94, r/w errs 0/1, ifcnt 50, reads/writes 31486/16, timeouts 0, DMA errs 0, CC errs 0
          Driver 1: standstill, SG min 16, r/w errs 0/1, ifcnt 50, reads/writes 31485/16, timeouts 0, DMA errs 0, CC errs 0
          Driver 2: standstill, SG min 162, r/w errs 0/1, ifcnt 51, reads/writes 31485/16, timeouts 0, DMA errs 0, CC errs 0
          Driver 3: standstill, SG min 78, r/w errs 0/1, ifcnt 50, reads/writes 31485/16, timeouts 0, DMA errs 0, CC errs 0
          Driver 4: standstill, SG min 38, r/w errs 0/1, ifcnt 44, reads/writes 31486/16, timeouts 0, DMA errs 0, CC errs 0
          Driver 5: standstill, SG min 28, r/w errs 0/1, ifcnt 45, reads/writes 31485/16, timeouts 0, DMA errs 0, CC errs 0
          Driver 6: standstill, SG min 24, r/w errs 0/1, ifcnt 45, reads/writes 31485/16, timeouts 0, DMA errs 0, CC errs 0
          === DDARing 0 ===
          Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
          Segments left 0, axes/extruders owned 0x00000803, drives owned 0x00000803
          Code queue is empty
          === DDARing 1 ===
          Segments left 0, axes/extruders owned 0x00000000, drives owned 0x00000000
          Code queue is empty
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          File2 is idle in state(s) 0
          Queue2 is idle in state(s) 0
          === CAN ===
          Messages queued 122766, received 1235340, lost 0, ignored 0, errs 0, boc 0
          Longest wait 3ms for reply type 6061, peak Tx sync delay 386, free buffers 26 (min 25), ts 66559/66558/0
          Tx timeouts 0,0,0,0,0,0
          === Network ===
          Slowest loop: 31.33ms; fastest: 0.00ms
          Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          === WiFi ===
          Interface state: active
          Firmware version 2.2.1
          Module reset reason: Power up, Vcc 3.39, flash size 2097152, free heap 40956
            @CorvoConV @dc42 has increased the MaxHeatersPerTool from 2 to 8. This should be available in the next firmware release. https://github.com/Duet3D/RepRapFirmware/commit/e31003fdcb3b3ffaf33d8a3150e32c88bdf83e6d
            I think no one had ever asked for more!
            0 dc42 committed to Duet3D/RepRapFirmware
            Increased max heaters per tool on Duet 3 Mini from 2 to 8
              @droftarts
              Nice, thanks for all.
              • dwuk3dundefined
                dwuk3d
                Dual IDEX sounds really interesting, I saw a brief glimpse of your printer on Instagram and it looks really good and congratulations on your award.
                You might want to consider upgrading to a 6hc board - so that you can run different gcode on the two gantries in parallel.
                Would be interested in finding out more about your design - such as the kinematics your are using, bed probing, head alignment etc.
