    Problem with daemon.g timing
    Gcode meta commands
    146
    • awitcundefined
      awitc
      My daemon.g looks like this:
      var pump_started = false
      var fans_started = false
      var fans_time_elapsed = 0 ; [s]
      var fans_time_disable = 30
      var feeder_time_elapsed = 0 ; [s]
      var feeder_time_disable = 8
      var dt = 500 ; loop delay time [ms]
      while true
      	; monitor current pressure
      	if {global.nozzle_pressure > global.nozzle_pressure_threshold}
      		M98 P"/macros/disable_extruder.g" ; stop extruder
      		M226 ; stop print
      		M118 S"Error: Nozzle pressure is too high!"; error message
      	if {global.pump_pressure > (global.target_pressure + global.pressure_difference_threshold)}
      		; if state.status == "processing"
      		M226 ; stop print
      		M118 S"Error: Pump pressure not within correct limits!"; error message
      	elif {abs(global.target_pressure - global.pump_pressure) < global.pressure_difference_threshold}	; if pressure is at the expected levels, resume print
      		if state.status == "paused"
      			M24 ; resume print job
      	; monitor temperature
      	if sensors.analog[9].lastReading  > global.pump_trigger_temp && var.pump_started == false
      		set var.pump_started = true
      		set var.fans_started = true
      		set var.fans_timer_reset = true
      		M42 P1 S1		; enable pump
      		M106 P3 S255	; enable fans
      	if sensors.analog[9].lastReading  < global.pump_trigger_temp && var.pump_started == true
      		set var.pump_started = false
      		set var.fans_started = false
      		M42 P1 S0 		; disable pump immediately
      	if var.fans_started == true
      		set var.fans_time_elapsed = var.fans_time_elapsed + {var.dt} / 1000 ; [s]
      		if var.fans_time_elapsed >= var.fans_time_disable
      			set var.fans_time_elapsed = 0
      			M106 P3 S0 		; disable fans
      	; monitor pellet feeder
      	if global.feeder_started == true
      		set var.feeder_time_elapsed = var.feeder_time_elapsed + {var.dt} / 1000 ; [s]
      	  	if var.feeder_time_elapsed >= var.feeder_time_disable
      			set var.feeder_time_elapsed = 0
      			set global.feeder_started = false
      			M42 P5 S0		; disable feeder
      			M118 S"Pellet feeder disabled"
      	G4 P{var.dt} ; loop delay, 500ms, P = [ms], S = [s]
      	; if nozzle_size changed, save the new value and update volume
      	M98 P"/macros/update_nozzle_size.g"
      	set global.reference_volume = global.volume_coefficient * global.nozzle_size
      At first it was working fine, but I have added more and more stuff to it. The last change was the addition of the feeder code. It should trigger every 8 seconds or so, but as of now it is more like 30 seconds. Is there anything very wrong in my code?
      The macros I use in the code are also like 1-3 lines of code, containing M42 and echo commands.
      • fcwiltundefined
        fcwilt @awitc
        @awitc
        I don't think M226 is the command you want.
        And where are the bits of code that exit the while loop?
        Thanks.
        awitcundefined 1 Reply Last reply Reply Quote 1
        • awitcundefined
          awitc @fcwilt
          @fcwilt The M226 is maybe not the best, but it is needed for when I am stopping the print due to problems with a custom extruder (temps, pressure errors) or pausing it from gcode to wait for initial pressure to raise. In this post I was focused on the while true and G4 Px duo, where I want an infinite loop that checks several things ever x milliseconds. That is also why the loop doesn't ever exit. Also I remember to have read somewhere that without it the daemon.g executes slower, like every several seconds or so.
          fcwiltundefined infiniteloopundefined dc42undefined 3 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @awitc
            @awitc
            Well the docs for M226 say it is to be used from within the GCODE file being printed:
            Use M226 when a pause is required in the GCode file being printed, for example to pause after a particular layer has completed. It waits until all the moves in the queue have been completed.
            I think M25 is the correct code but if the docs are correct it doesn't stop the print, just pauses it.
            The daemon code is run every 10 seconds but in your case I have no idea what is going to happen since you don't allow the while loop to exit.
            Perhaps @dc42 will notice and address your issues.
            • infiniteloopundefined
              infiniteloop @awitc
              @awitc
              have read somewhere that without [the while loop] the daemon.g executes slower, like every several seconds or so.
              As a self-assigned expert for infinite loops, I can confirm that 😉. But it is always better to study the documentation. For daemon.g, see the respective sections in Macros and GCode meta commands.
              With M226, the Notes state:
              Use M25 when a pause is required from a different source of GCodes (such as the web interface console, PanelDue or a Macro).
              Which, in your case, is true. Looking up M25, however, it says:
              Note that if a pause is commanded while a macro is being executed, the pause will be deferred until the macro has completed.
              … which puzzles me a bit, because your macro - the daemon - will never run up to completion. So, the only advice I can give on this one is to test both variants. Then use whichever of them works for you.
              Talking of tests: In order to spot the code lines where the daemon spends most of its time, you might want to comment-out single statements (or blocks of statements) temporarily. Then look whether the response times improve significantly.
              Some of your code can certainly be optimised, but the M98 calls are my primary suspect: Every time a macro is invoked, it has to be fetched from the SD card (Note:.on every iteration of the loop!). You can either unravel the macro code into daemon.g or try a fresh, high quality (e.g. very fast) SD card.
                dc42 administrators @awitc
                @awitc as @infiniteloop says, executing a M98 command frequently in a loop should be avoided, in particular the one at line 70 in your file.
                • awitcundefined
                  awitc @fcwilt
                  @fcwilt The idea of the while true loop was taken from this forum itself I think, to have it check faster than every 10 seconds. According to @dc42:
                  @dc42 said in daemon.g usage cases:
                  @OwenD said in daemon.g usage cases:
                  Does G4 pass control back to the main process when used in a loop?
                  Yes.
                  From this I understand that I effectively get a daemon.g running every G4 Px milliseconds at least (not taking into account the time it takes for the daemon to execute).
                  The choice between M226 and M25 was made because of this description:
                  Initiates a pause in the same way as if the pause button is pressed, except that execution of all prior GCode commands in the same input stream is completed first.
                  On the other hand M25:
                  M25 attempts to execute as quickly as possible
                  Even though the GCode dictionary mentions M25 to be the command to stop a print from DWC or some other source, the M226 in my case is like an extension of Gcode. I had to come up with a conditional check during printing.
                  The flow is as follows:
                  Print started -> Start Gcode toggles -> Custom macro starts extruder (controlled by a different board than the Duet3), Gcode paused by M226 in start gcode -> print paused till daemon.g checks for appropriate pressure (M24) -> continuous checks for any pressure jumps.
                  I imagined this as an extension of the Gcode, running along, not a definite break in the flow - like the M25.
                  The cases where I use my M226/M24 weren't causing problems yet, my print pauses at start, communicates with external controller for the extruder, resolves when pressure builds up fine. During the creation of this topic, these if statements were not checked, the delays have to stem from something else.
                  • awitcundefined
                    awitc @infiniteloop
                    @infiniteloop @dc42
                    This sounds like it! I will remove this macro from the daemon and figure out a different way of doing this.
                    Is there a good way of saving parameters while the Duet3 is running? This is how I have done it so far:
                    ; macro for updating the value
                    echo >"/sys/coef.g" "set global.coef = {global.coef}"
                    G4 P1
                    M98 P"coef.g"
                    echo "Updated val: ", global.coef
                    This is how the logic looks like (not direct code, because I don't have access to the printer right now), I have a variable in config.g, then the file coef.g contains an overwrite,
                    which is using a new value. In config, the macro is run at every start-up to load the new value from SD card. The global.coef can be overwritten during printer operation by other macros etc.
                    Looking at this code, I am feeling quite silly that I completely missed having a G4 P1 executing at EVERY loop iteration. I have focused on the code I added (the feeder checks) and that is when I noticed delays. The SD card saving macro I added couple of weeks ago, but didn't test it thoroughly (my oversight). Thanks a lot!
                    TLDR: avoid M98 in daemon.g, especially when it introduces another G4 delay.
                    edit:
                    @infiniteloop said in Problem with daemon.g timing:
                    took me a while 🙂
                    dc42undefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
                      @awitc yes that's a good way of saving values, provided you don't call that macro too often, because that might cause excessive wear on the SD card. I believe the G1 P1 call in that macro is not needed, because the echo command will complete and close the file before the M98 command is called. But why do you need the M98 call in that macro at all? Surely it just resets global.coeff to the value it already has?
                      awitcundefined 1 Reply Last reply Reply Quote 0
                      • awitcundefined
                        awitc @dc42
                        I didn't have the macro for changing nozzle size at hand, so I copied my other one and replaced this line, so that it only demonstrates the saving. Should look like this, but it is for volume measurement parameters:
                        echo "Previous val: ", global.coef
                        echo "Reference volume: ", global.reference_volume
                        echo "Actual volume: ", global.actual_volume
                        echo >"/sys/coef.g" "set global.coef = "^{global.coef * global.reference_volume/global.actual_volume}^""
                        G4 P1
                        M98 P"coef.g"
                        Here the result is calculated and stored in the coef.g file and then loaded so the printer has the updated value, too.
                          infiniteloop @awitc
                          @awitc
                          Extending on what @dc42 stated above, it’s fine to permanently store a variable like this, but it comes at a cost. You only need the file storage for some parameters to survive a reboot, reset or shutdown. During runtime, global variables do the job.
                          Now, if you have two macros, one to store a set of globals, and one to restore these from disk (SD card), you just have to spot some events who potentially lead to a reset/shutdown, such as pause or end of print, and call the ”store” macro on these events.
                          The ”restore” macro has to be called only once, either at the end of your config.g or when you start a print - whatever suits your needs.
                          Essentially, you just have to write the ”store” macro, as it creates (by using ”echo”) an executable file which then IS the ”restore” macro. If you need some sample code on how to compose complex expressions, just drop a note.
                          Well, that’s just a millisecond. However note the usage of G4 at this line in your daemon.g:
                          This one is essential for granting time to parallel processes. For details, look up the ”daemon” sections from the links in my previous post.
                          If a macro has to wait for the completion of some code in the printing queue or from another macro, don’t use a delay, use M400 instead.
