    rr_filelist documentation clarification
    Third-party software
    • stuartofmtundefined
      stuartofmt
      The documentation (https://github.com/Duet3D/RepRapFirmware/wiki/HTTP-requests)
      and actual for rr_filelist response do not match. I'm happy with the actual but want to check in case there is a bug and it will change. If not a bug then the documentation would benefit from a correction.
      I'm in the process of changing one of my plugins (duetBackup) so that it can be used (remotely) to backup standalone printers.
      For this - I'm looking to switch to rr_ APIs (from /machine) for simplicity.
      I'm currently testing rr_filelist against a remote SBC
      The following is the actual result of rr_filelist. Essentially it only (and usefully) returns the files array described in the documentation.
      S C:\Users\stuar\Github\DWC\duetBackup> curl http://192.168.10.140/rr_filelist?dir=/macros/
      StatusCode        : 200
      StatusDescription : OK
      Content           : [{"type":"d","name":"Piezo","date":"2025-01-18T14:27:19"},{"type":"d","
                          name":"duetLapse_Test","date":"2025-05-01T21:29:14"},{"type":"d","name"
                          :"Pen Calibration","date":"2025-01-25T10:05:36"},{"type":"...
      RawContent        : HTTP/1.1 200 OK
                          Content-Length: 516
                          Content-Type: application/json
                          Date: Wed, 07 May 2025 09:26:27 GMT
                          Server: Kestrel
                          nam...
      Forms             : {}
      Headers           : {[Content-Length, 516], [Content-Type, application/json], [Date, Wed,
                          07 May 2025 09:26:27 GMT], [Server, Kestrel]}
      Images            : {}
      InputFields       : {}
      Links             : {}
      ParsedHtml        : mshtml.HTMLDocumentClass
      RawContentLength  : 516
      • stuartofmtundefined stuartofmt marked this topic as a question
      • chrishammundefined
        chrishamm administrators @stuartofmt
        @stuartofmt Thanks for pointing this out, I've got a fix ready. For now you can set first=0 to get a properly formatted response which should match the RRF format.
        Duet software engineer
        stuartofmtundefined 1 Reply Last reply Reply Quote 0
          stuartofmt @chrishamm
          @chrishamm
          Thanks. Confirmed working with first=0
          • stuartofmtundefined stuartofmt has marked this topic as solved
