    Simultaneous dual extrusion - Part 2
    • Timothee Leblondundefined
      Timothee Leblond
      Re: Simultaneous dual extrusion
      @dc42 I'm coming back to you as I've been working on a Gcode processor to add a second E value as suggested in your answer.
      G1 Xxxx Yyyy E3.2:12.0
      Should I map this as 2 different tools?
      Thank you!
        dc42 administrators @Timothee Leblond
        @Timothee-Leblond no, define a single tool with 2 extruders.
        Timothee Leblondundefined 1 Reply Last reply Reply Quote 0
          Timothee Leblond @dc42
          Great thank you! Would you also know if changing the Extruder % through the paneldue will impact both extruders? If yes, Is there a way to control both Extruder1% and Extruder2%?
          Thank you for your help!
          Timothee
            @Timothee-Leblond you should get a separate extrusion coefficient button for each extruder on PanelDue.
