    IOs 5V_ext pin not working
    • FelixUCFundefined
      FelixUCF
      I am using a Duet 6HC to control a custom 3D-printer.
      I am trying to control a pressure controller, which requires 5V signals. I would like to use the 5V_ext pin from one of the IOs. However, measuring it (5V_ext to GND) shows OL. The 12V derived internal 5V seems to working (red status light).
      Now, I am wondering if the 5V_ext pin only supplies 5V if an external 5V power supply is connected?
      Thanks in advance!
      Best, Felix
      fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @FelixUCF
        @FelixUCF
        I seem to recall there is a jumper that determines what appears on that pin.
        Did you check it?
        Did you check
          dc42 administrators @FelixUCF
          @FelixUCF which version 6HC board do you have?
          The 5V_ext supply on the IO_ connectors of the 6HC is derived from the main 5V supply through a diode. Older 1HC boards that do not support 48V VIN also have a PTC fuse in that circuit. The 5V_ext voltage on the IO_ connectors will be missing if either the diode or the fuse is open circuit.
