    Bed temperature fault
    • bernardomattiucciundefined
      bernardomattiucci
      Hello everyone,
      today I was mounting a protective cover on the head of my printer, so as to cover the connections of the various cables. I had the printer on, because I didn't think it would be that much trouble to do it (I only had to tighten 2 M3 bolts).
      The connections include:
      • Extruder motor
      • Hotend
      • Temperature sensor
      • Extruder fan
      • Layer fan
      • LED lighting
      • BlTouch
      • Accelerometer
      I placed the cover and started screwing in the bolts, but at some point on the duet's display, the platen temperature sensor went “fault.”
      The error gave me several times, but I still didn't understand why.
      I would like to understand the logic so I can possibly detect some short--because then it worked and never gave me any error again.
        Pressure on a connector causing it to disconnect briefly perhaps?
        What was the exact fault? What did the temp graph show?
