    External 5V on duet 3HC
    • shirnschallundefined
      shirnschall
      Hi, I have recently upgraded from duet2 + duex 5 to a duet3 6hc with duet 3HC expansion board. However, I am having issues configuring/using the expansion board.
      My setup has a small 5V psu that powers the mainboard (and previously also the duex board). When I want to start a print I use the pson pin to switch mains to the 24V psu and turn it off when all temperatures are back to normal. This worked great with the duet2 but since I cannot find a way to add 5V to the can expansion board it is off when I try to configure it/cannot read sensors when the 24V supply is off.
      What is the intended way wo use the pson/ext5V when using expansion boards on duet 3?
      My printer: DIY 2020 extrusion CoreXY with E3D Tool-changing and Duet3 (https://github.com/shirnschall/HS-Bot-Project)
        You can re-execute the config.g after the board is powered up in order to configure it. Or have the 3HC config in a separate macro you can call after you've executed PSON.
