    warning: position tolerance exceeded, But only in one direction
    • Hannahundefined
      Hannah
      My CNC machine has 2 motors on the X axis, they are 1HCL boards.
      Board 51 keeps giving me " warning: position tolerance exceeded" by the dozens. But only when traveling in the positive direction. This happens at pretty much every speed
      I tried:
      • setting acceleration verry low
      • reduced the amount of microsteps
      • played with dozens of feedrates
      The machine seems to work great besides spamming my console with warnings.
      Board 50 never gave me a warning, even at ludicrous speeds. And it doesn't happen in the negative direction.
      I am out of ideas. Does anyone have any suggestions?
      Running FW 3.6.0-rc.3
      config.g:
      G90                            ; send absolute coordinates...
      M550 P"RatRig"                 ; set machine name
      M552 P0.0.0.0 S1               ; enable network with DHCP
      M586 P0 S1                     ; enable HTTP
      M586 P1 S1                     ; enable FTP
      M586 P2 S0                     ; disable Telnet
      ; Internal Serial
      M575 P1 S7 B57600
      M575 P2 S1 B57600
      ; Wait for CAN startup
      G4 S1
      ; Define CAN endstops
      M574 X1 S1 P"50.io0.in"
      M574 Y1 S1 P"52.io0.in"
      M574 Z1 S1 P"53.io0.in"
      ; Define CAN motors
      ; X0 adress 50
      M569.1 P50.0 T2 C1000 R100        ; Quadrature encoder, 1000 steps, 100  Proportional constant
      M569 P50.0 S0 D0                  ; Start in open loop mode
      ; X1 adress 51
      M569.1 P51.0 T2 C1000 R100        ; Quadrature encoder, 1000 steps, 100  Proportional constant
      M569 P51.0 S0 D0                  ; Start in open loop mode
      ; Y0 adress 52
      M569.1 P52.0 T2 C1000 R100        ; Quadrature encoder, 1000 steps, 100  Proportional constant
      M569 P52.0 S0 D0                  ; Start in open loop mode
      ; Z0 adress 53
      M569.1 P53.0 T2 C1000 R100        ; Quadrature encoder, 1000 steps, 100  Proportional constant
      M569 P53.0 S0 D0                  ; Start in open loop mode
      ; Define coordinate sytem
      M584 X50.0:51.0 Y52.0 Z53.0        ; set drive mapping
      M350 X8 Y8 Z8 I1                   ; configure microstepping with interpolation
      M92 X160 Y160 Z400                 ; set steps per mm
      M566 X0 Y0 Z0                      ; set maximum instantaneous speed changes (mm/min)
      M203 I10                           ; set minimum speed to (mm/min)
      M203 X3200 Y3200 Z600              ; set maximum speeds (mm/min)
      M201 X300  Y300  Z300              ; set accelerations (mm/s^2)
      M906 X4000 Y4000 Z4000 I70         ; set motor currents (mA) and motor idle factor in per cent
      ;M84 S30                           ; set idle timeout
      M208 X0 Y0 Z-130 S1               ; set axis minima
      M208 X1450 Y1000 Z0 S0            ; set axis maxima, Lengte endstop draad Y = 500
      ; Z-Probe 3D touch
      M558 K0 P5 C"!io7.in" H2 A3 S0.01 T3200 F600:150 ; Probe 0, Mode 5, IO7, Dive height, Probe amount, Travel speed, Feedrate
      ; Z-Probe toolsetter
      M558 K1 P8 C"io8.in" H2 A3 S0.01 T3200 F800:400 ; Probe 1, Mode 8, IO7, Dive height, Probe amount, Travel speed, Feedrate
      ; Spindle
      M950 R0 C"out1" L3000:24000 Q2000      ; Spindle 0, Pin out1, 24k RPM, 2000Hz PWM
      ; START MACHINE !!!
      M453                            ; Switches to CNC mode.
      G54                             ; Selects coordinate system 1.
      M501                            ; load saved parameters from non-volatile memory
      M98 P"mos.g"
      homex.g:
      ; homex.g
      ; called to home the X axis
      M569 P50.0 D0        ; Make sure we are in open loop mode
      M569 P51.0 D0        ; Make sure we are in open loop mode
      G91                  ; relative positioning
      G1 H1 X-1500 F2000   ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F3200       ; go back a few mm
      G1 H1 X-10 F300      ; move slowly to X axis endstop once more (second pass)
      G92 X0
      G90                  ; absolute positioning
      G1 X50 F3000            ; Move to a known-safe position
      M400                    ; Wait for the move to complete
      G4 P200                 ; Wait for the motor to settle
      M569 P50.0 D5           ; Switch to assisted open loop mode
      M569.6 P50.0 V1         ; Perform the calibration manoeuvre for a quadrature shaft encoder
      M569 P51.0 D5           ; Switch to assisted open loop mode
      M569.6 P51.0 V1         ; Perform the calibration manoeuvre for a quadrature shaft encoder
      G1 X0                   ; Move back to X0
      • samlevy0515undefined
        samlevy0515
        motors have couplings? check tightness, loose coupling could cause slippage in one direction.
        infiniteloopundefined 1 Reply Last reply Reply Quote 0
        • infiniteloopundefined
          infiniteloop @samlevy0515
          @samlevy0515 That's rare. Does this insight come from chatGPT?
