    Gantry leveling
    CNC
    • Alijambo73undefined
      Alijambo73
      I have 2 z motors and I'm strying to auto level my gantry but am having some issues. I have my bed.g as
      while true
          G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
          G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
          if abs(move.calibration.initial.deviation) < 0.01 || iterations > 3
              break
      when I first tried this the other day it worked perfectly but now when I run G32 my machine crashes into the bed of my cnc without even moving to the x,y corrdinates.
      I can't figure out why it woked Saturday but not today. There were not any other changes made to my config.g or anywhere else.
      ; General
      G90                                          ; absolute coordinates
      M83                                          ; relative extruder moves
      M550 P"Duet3CNC"                             ; set hostname
      M453                                         ; select CNC mode
      ; Accessories
      M575 P1 S0 B57600                            ; configure PanelDue support
      ; Smart Drivers
      M569 P0.0 S1 D3                              ; driver 0.0 goes backwards (X axis)
      M569 P0.1 S0 D3                              ; driver 0.1 goes backwards (Y axis)
      M569 P0.2 S1 D3                              ; driver 0.2 goes forwards (Z axis)
      M569 P0.3 S1 D3                              ; driver 0.3 goes forwards (U or Y2 axis)
      M569 P0.4 S1 D3                              ; driver 0.4 goes forwards (V or Z2 axis)
      ; Motor Idle Current Reduction
      M906 I30                                     ; set motor current idle factor
      M84 S1000                                    ; set motor current idle timeout
      ; Axis
      M669 K0                                      ; set Cartesian kinematics
      M584 X0.0 Y0.1:0.3 Z0.2:0.4 U0.3 V0.4 P5     ; U=Y2 V=Z2 set axis mapping
      ;M584 X0.0 Y0.1:0.3 Z0.2:0.4 P3
      ; Leadscrew locations for automatic Z squaring
      M671 X58:1183 Y80:80 S5                  ; leadscrew positions for Z0 (left), Z1 (right)
      M350 X16 Y16 Z16 U16 V16 I1                  ; configure microstepping with interpolation
      M906 X1200 Y1100 Z1100 U1100 V1100           ; set axis driver currents
      M92 X100.067 Y100.067 Z400 U100.067 V100.067 ; configure steps per mm
      M566 X300 Y300 Z60 U300 V60                  ; set maximum instantaneous speed changes (mm/min)
      M203 X12000 Y9000 Z3000 U9000 V3000          ; set maximum speeds (mm/min)
      M201 X300 Y300 Z60 U300 V60                  ; set accelerations (mm/s^2)
      M208 X0 Y0 Z-150 U0 V-150 S1                 ; Z min is -150 (full depth)
      M208 X1252 Y2467.8 Z150 U2467.8 V150 S0      ; set axis maximum
      M574 X1 S1 P"io1.in"                         ; configure active-high endstop for low end on X via pin io2.in
      M574 Y1 S1 P"io2.in+io3.in"                  ; Y endstops on io2.in (Y) and io3.in (U)
      M574 Z2 S1 P"io4.in+io5.in"                  ; Z homes to the **max** end (top)
      ; Z Probe Configuration
      M558 P5 C"!io6.in" H5 F120 T6000             ; Digital probe using io6.in, active-low
      G31 P850 X-10 Y-10 Z5.89                     ; set Z probe trigger value, offset and trigger height
      I am using a 3 way touchplate and the bit to probe. Everything works as expected when I run my probe z macro to find the surface of the work peice.
      please let me know if you have any insights.
        Phaedrux Moderator @Alijambo73
        @Alijambo73 said in Gantry leveling:
        Are you starting from a homed state?
        Alijambo73undefined 1 Reply Last reply Reply Quote 0
          Alijambo73 @Phaedrux
          @Phaedrux yes
            Alijambo73 @Alijambo73
            @Alijambo73 it seems it had something to do with the z offset getting saved in config-override.g. this seems to be working well```
            code_text
            G28
            G1 X58 Y100 F3000
            ; === Run Z probing macro ===
            G91                                       ; relative
            M291 P"Connect probe and jog tip over Z touchplate. Press OK to continue." R"Z Probe" S3
            G38.2 Z-100 F75
            G1 Z2 F300
            G38.2 Z-100 F45
            G4 P0.1
            G92 Z5.89
            G1 Z5 F300
            G90                                       ; absolute
            ; === Proceed with squaring ===
            M584 Z0.2:0.4 P3
            M671 X58:1183 Y100:100 S15
            G10 L2 P1 Z0
            var iterations = 0
            while true
                G1 X58 Y100 F3000
                G30 P0 Z-99999
                G1 X1183 Y100 F3000
                G30 P1 Z-99999 S2
                set var.iterations = var.iterations + 1
                if abs(move.calibration.initial.deviation) < 0.01 || var.iterations >= 2
                    break
            M584 X0.0 Y0.1:0.3 Z0.2:0.4 U0.3 V0.4 P3
            M671 X58:1183 Y100:100 S5
            M118 P0 S"Z gantry squaring complete."
