    BL touch and homing
    • Mike72
      Mike72 last edited by
      Hello, I am trying to get my bl touch configured and working. It is installed, deploy and retract work fine. How do I get it working correctly in conjunction with the homing files? Also do I disable my z endstop, and if so how? Also can I may it start automatically at the start of every print?
      I am also getting this error: Error: G30: Insufficient axes homed for bed probing
      Here is my config file.. it may be a mess as I was trying a few different things to get the BL up and running.
      ; generated by RepRapFirmware Configuration Tool on Thu Jan 11 2018 16:25:07 GMT-0800 (Pacific Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M82 ; ...absolute mode
      G10 P0 S0 R195
      G10 P1 S0 R195
      T0
      T1
      T-1
      G10 P0 S235 R195 ; Set tool 0 operating and standby temperatures
      G10 P1 S235 R195 ; Set tool 1 operating and standby temperatures
      G28 ; home all axes
      G28 ; home all axes
      G32; probe - bed compensation
      G1 Z30 F5000 ; lift nozzle
      M208 X230 Y230 Z200 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S0 ; Define active high microswitches
      ; BL Touch
      M307 H3 A-1 C-1 D-1
      M558 P5 X0 Y0 Z1 H5 F100 T2000
      G31 X53 Y-5 Z-4.80 P25
      ; Auto Bed Compensation
      M561
      M98 Pdeployprobe.g
      ; Probe the bed at 5 points
      G30 P0 X15 Y15 H0 Z-99999
      G30 P1 X15 Y175 H0 Z-99999
      G30 P2 X185 Y175 H0 Z-99999
      G30 P3 X185 Y15 H0 Z-99999
      G30 P4 X100 Y100 H0 Z-99999 S
      M98 Pretractprobe.g
      M569 P4 S1 ; Drive 4 goes forwards
      M584 X0 Y2 Z1 E3:4
      M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
      M92 X86.5 Y86.5 Z1048 E420:420 ; Set steps per mm
      M566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180 E1200:1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250:250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M140 H-1 ; Disable heated bed
      M305 P1 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S280 ; Set temperature limit for heater 1 to 285C
      M305 P2 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 2
      M143 H2 S280 ; Set temperature limit for heater 2 to 285C
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 X9 Y0 Z0 ; Set tool 0 axis offsets
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 X-9 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M550 PMy printer ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P1 S1 I0 F500 H2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      • Mike72
        Also another issue, How do I keep both hot ends up to active temp when using dual extursion? On keeps dropping to standby temp.
        thank you
          @Mike72:
          thank you
          Set the active and standby temperatures the same. But then the non-printing nozzle is likely to ooze badly. The purpose of standby temperatures is to control oozing.
          • Mike72
            ok, So trying to get the BL touch working…. got pretty close... but now I am stuck. I can log in thru pronterface only...
            Wifi does not connect automatically when powering up.
            Printer is now online.
            ok T B:2000.0 /0.0
            ok T B:2000.0 /0.0
            ok T B:2000.0 /0.0
            ok T B:2000.0 /0.0
            Never had this message before... what is causing it?
            SO I run M552 S1, able to get wifi up and running.
            When I try to log on the web site, page loads up, but right away the window for manual bed probing loads up. But none of the buttons work, and I am stuck there. I can hit the ok button and the windows close, but nothing works. It doesnt show my extruders, onlt a bed heater, which I dont have. I also notice my y motors (I have dual motors) making noise for a little bit when starting up which they didnt do before... but no movement). Can someone take a look at my config file and see what got screwed up?
            G91 ; Send relative coordinates...
            G10 P0 S0 R195
            G28 ; home all axes
            ; BL Touch
            M307 H3 A-1 C-1 D-1
            M557 X10:190 Y10:190 S25
            M584 X0 Y2 Z1 E3:4
            G10 P1 X18 Y0 Z0 ; Set tool 1 axis offsets
              @Mike72:
              ok T B:2000.0 /0.0
              ok T B:2000.0 /0.0
              ok T B:2000.0 /0.0
              ok T B:2000.0 /0.0
              Probably Pronterface is sending M105 commands.
              @Mike72:
              When I try to log on the web site, page loads up, but right away the window for manual bed probing loads up. But none of the buttons work, and I am stuck there. I can hit the ok button and the windows close, but nothing works. It doesnt show my extruders, onlt a bed heater, which I dont have. I also notice my y motors (I have dual motors) making noise for a little bit when starting up which they didnt do before… but no movement). Can someone take a look at my config file and see what got screwed up?
              Remove that G32 command. Do not try to probe the bed in config.g.
              • Mike72
                Thank you… I removed G32 and still had the problem. I ended up removing G28 ; home all axes and that seemed to fix the problem..
                I guess I am having trouble with where the homing and probing files should be located... should they be put in my slicers gcode to run with the imported file? Or located on the duet?
                  You can either home and (if you want) probe manually after you turn the printer on, or include homing commands (and probing commands if you want) in the slicer start GCode.
                  The main problem was with where you had the probing commands, i.e. before many important parameters were set up. They would have worked close to the end of the file. However, it's generally a bad idea to have any movement commands in config.g for two reasons:
                  1. Safety: It's a bad idea to have machinery move as soon as you power it on.
                  2. If you have a power failure, then when the power comes back on you will not want the printer t home and probe with a print already on the bed.
