    Power cuts out when homing.
    845
    • Crisco80
      Crisco80 last edited by
      I am running a delta printer. Got everything wired up and for 24 hours, everything worked fine. Calibrated and did a few test prints. Went to calibrate a lil more after adjusting the bed and while uploading a different file, got an upload error. Then disconnected and refused to reconnect. Checked the printer. No power.
      Tested multiple psu's, no wires shorting to ground. Deut board on standoffs. Not running the hot end or the heat bed, yet anytime I try to home the printer, power cuts out again.
      Unplugged all steppers, and plugged just one back in. Works fine on all 3 towers. Add in a second stepper, 50/50. Sometimes it will power off, sometimes it won't (doesn't matter which combo of steppers or axis I try, all have the same 50/50 result). Add all 3 back in, 100% whether I home one axis or all, power cuts and it shuts off.
      Bought the duet I think in August and just got around to putting it in this last week.
      Steppers all getting 3.3v measured with a multimeter.
      All capacitors look fine, no burned or scorch marks.
      Any suggestions would be appreciated as it looks like it's the driver chips on them at this time 😞
        First thing to check is that the screws in the power input terminal block are tight.
        Does the blue LED on the Duet flicker when this problem occurs?
        • Crisco80
          Connections for power input are nice and tight, good full contact. Blue light is solid (never flickers) during any and all activities. Now cuts out moving any single axis on it's own if more than one stepper is plugged in. Nothing else is running off the board, just steppers and endstops.
            If you run M122 after one of these events, what does it report for minimum, maximum and present input voltage, and number of under-voltage events?
            • Crisco80
              Supply voltage: min 9.1, current 13.0, max 13.8, under voltage events: 35, over voltage events: 0
              • Crisco80
                Here is the full log just in case it provides any further insight:
                Send
                Clear Log
                9:57:01 am
                M122
                Used output buffers: 3 of 32 (7 max)
                RepRapFirmware for Duet WiFi version 1.19 running on Duet WiFi 1.0
                Board ID: 08DDM-9FAM2-LW4S4-6JTDA-3S46T-K3TBX
                Static ram used: 21176
                Dynamic ram used: 96040
                Recycled dynamic ram: 1568
                Stack ram used: 1304 current, 4840 maximum
                Never used ram: 7448
                Last reset 00:01:05 ago, cause: power up
                Last software reset reason: User, spinning module GCodes, available RAM 3232 bytes (slot 2)
                Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                Error status: 0
                Free file entries: 10
                MCU temperature: min 13.8, current 18.8, max 19.4
                Driver 0: stalled standstill
                Driver 1: stalled standstill
                Driver 2: stalled standstill
                Driver 3: standstill
                Driver 4: standstill
                Date/time: 2018-01-21 09:57:00
                Slowest main loop (seconds): 0.005901; fastest: 0.000034
                MaxReps: 3, StepErrors: 0, FreeDm: 240, MinFreeDm 237, MaxWait: 4073ms, Underruns: 0, 0
                Scheduled moves: 3, completed moves: 3
                Bed compensation in use: none
                Bed heater = 0, chamber heater = -1
                Segments left: 0
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                Network state is running
                WiFi firmware version 1.19
                WiFi MAC address 60:01:94:34:39:ea
                WiFi Vcc 3.15, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 38720
                WiFi IP address 192.168.0.17
                WiFi signal strength -67dBm
                HTTP sessions: 1 of 8
                Socket states: 2 0 0 0 0 0 0 0
                Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                  That's the problem. The input voltage is regularly dropping below the minimum 9.5V. Possibly causes include:
                  1. Bad connection between the PSU output and the VIN terminal block;
                  2. Excessive load on the PSU, e.g. bed heater turned on and the PSU doesn't have the capacity to handle it;
                  3. PSU has a 115V/230VAC input voltage selector switch, and your mains is 115V but you have it set to 230V;
                  4. Faulty PSU.
                  • Crisco80
                    2 different psu's both running 115v. I could understand one being faulty, but 2 is doubtful.
                    Only parts running are the steppers, endstops, and one always on fan. I kept the hotend and heatbed off when this happens.
                    Main power is nice and tight in the terminal block, however, ther terminal block itself has a bit of slop/rotation where it connects to the board itself. When tightening or loosening, it tends to slightly twist whichever direction you're going, so this might be where the issue is then. I'll flip it over and examine the solder points on the bottom of the main power terminal after work
                    • Crisco80
                      Thanks so much dc42! It was apparently two fault psu's. Bought a 24v psu and the original issue has been resolved. In my haste I failed to realize I needed a 24v heater cartridge for my hot end now haha glad the previous issue is resolved, on toward more waiting now lol
                        I'm glad you solved it. One possible cause I didn't mention was the wires between the PSU and the Duet being too thin, so that when the bed heater turns on the voltage drop in those wires is too great.
