    Extruder motor shutters but doesnt really turn
    • A Former User
      A Former User last edited by
      When I try to activate my Extruder motor just to test it. Its just makes noise and shutters. I've heated the hot end up to 200. This motor is different then the rest on my printer so following their color scheme for the wiring is not necessarily the same. The motor I have is 17HS10-0704S. I was not able to find a wiring diagram for it on google so I am hoping some one on here will have an idea. Maybe its something in my config file as well not sure. I will post it just to make sure:
      Thank you
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X365 Y250 Z295 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
      M307 H3 A-1 C-1 D-1 ;
      M558 P5 X0 Y0 Z1 H5 F100 T2000
      G31 X-43 Y0 Z1.75 P25
      M557 X15:365 Y15:250 S68 ; Define mesh grid
      M584 X0 Y1 Z2 E3
      M569 P0 S1 ; Drive 0 goes forwards - X
      M569 P1 S0 ; Drive 1 goes backwards - Y
      M569 P2 S0 ; Drive 2 goes backwards - Z
      M569 P3 S1 ; Drive 3 goes forwards - Extruder
      M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation 16
      M92 X80 Y80 Z1600 E800 ; Set steps per mm 16
      M566 X600 Y600 Z12 E120 ; Set maximum instantaneous speed changes (mm/min) - (JERK)
      M203 X6000 Y6000 Z500 E400 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E250 ; Set accelerations (mm/s^2)
      M204 P1000 T1000 ; Set Max acceleration for P=printing moves and T=travel moves
      M906 X1600 Y1600 Z900 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M305 P0 T99600 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1 - HOTEND E3d
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M307 H1 A340.0 C140.0 D5.5 B0 ;Hotend E3d pid
      M563 P0 D0 H1 ; Define tool 0
      M550 PRodriguez Black Widow ; Set machine name
      M552 S1 ; Enable network
      M587 S"RCMP Surveillance" P"241428433" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
        The first thing to do is power off the Duet, disconnect the stepper motor from the Duet and check that it is phased correctly:
        • If you have a multimeter, check that there is continuity between pins 1 and 2 on the 4-pin connector that plugs in to the Duet, and between pins 3 and 4, but no continuity between 1 or 2 and 3 or 4.
        • If you don't have a multimeter, first feel how easy it is to spin the spindle between your fingers. Then short pin 1 to pin 2 on the connector that plugs into the Duet. If pins 1 and 2 are connected to the same phase, it will be much harder to spin the spindle with those pins shorted together.
        • A Former User
          Yes there is continuity between pins 1 and 2 and there is continuity between pins 3 and 4 but not between any other combination
            In that case, the problem could be a faulty driver on the Duet. With power off, try connecting the motor to the E1 motor output instead of E0, and put this command in config.g just before your M350 command:
            M584 X0 Y1 Z2 E4
            • A Former User
              My apologies DC42 I was testing the wrong motor when I was testing for continuity. There was a bad connection on the wires. Im just doing an actual test print now. I think im good. Thank you yet again for pointing me in the right direction
