    Home Z axis
    • parovoZZ
      parovoZZ last edited by
      Hi!
      I have a cartesian printer clone Ultimaker with Z endstop at the bottom. In Homeall.g wrote as follows:
      [c]
      ; homeall.g
      ; called to home all axes
      ; Relative positioning
      G91
      ; Lift Z
      G1 Z5 F6000
      G1 X-221 Y-221 Z351 F6000 S1
      G90;
      G92 Z355;
      G91;
      G1 X5 Y5 Z-5 F6000
      ; Fine home X and Y
      G1 X-255 Y-225 S1
      G1 Z5 F500 S1
      ; Absolute positioning
      G90;
      G92 Z355 ;
      G1 X15 Y15 F6000
      G1 Z0 F6000;
      [/c]
      Correctly applied command G92? Is there an elegant solution?
        Yes, instead of using G92, set your M208 S0 Z parameter to 355.
        • parovoZZ
          Of course:
          [c]M208 X0 Y0 Z0 S1 ; Set axis minima
          M208 X220 Y220 Z355 S0 ; Set axis maxima[/c]
          In this case, the origin point is at the bottom. I want her upstairs. To the extruder.
          Sorry for my English.
            That's right. Assuming you have the Z axis defined as high end (Z2 in the M574 command), when the Z endstop switch is triggered the Z position will be set to 355.
            • parovoZZ
              Z2 = probe? Z-probe is not located.
                Z2 mean an endstop switch at the high end. It's S2 that selects type=Z probe.
                • parovoZZ
                  Thanks you thanks you thanks you!!!
                  All work!
