Pop gcode last status on www duetcontrol, can it be removed?
  • Everytime I change temperature or fan, or something this pops, and it's a bit annoying since it takes 2 secs to disappear and the close button is small (on iphone specially)
    Is there any option to remove this? Cleaning the gcode console doesn't affect this, I need to force emergency shutdown to remove it
    I'm currently using:
    Firmware Version: 1.20 (2017-12-23)
    WiFi Server Version: 1.20
    Web Interface Version: 1.20-RC3
    If the same message keeps appearing, that usually means that you had another device connected to the Duet via the network and you didn't disconnect it before turning it off.
  • This bug/feature really needs squishing. Sometimes I can have a dozen popups to clear 😞
  • @dc42:
    Oh, is THAT what causes that? That's good to know.. it becomes annoying (and confusing) to see messages from 24 hours ago popping up on in the browser.
  • @dc42:
    Anyhow it could be interesting (for me XD) to have this removable for future options. On the iPhone is quite annoying to just change the fan since it’s at the end of the screen, you change, pops, then you need to wait or press the x, then you can finally adjust the fan then it pops…
    I think is nice to have a last print status with print time etc (really nice btw) but also I would be ok with this info not popping up and just staying on the gcode console log. Or just one option to choose? Not mission critical indeed hahahaha anyway thanks! Duet3D rocks!
