    Issue with Smarteffector
    • DjDemonD
      DjDemonD last edited by
      So I replaced my smarteffector PCB a while back as I blew the LEDs, but it functioned well as a z-probe. The replacement one occasionally functions erratically. Now its really behaving badly.
      Sometimes triggers heavy, LED doesnt come on (motors are at 50% current so its not doing any damage), then it starts false triggering.
      Its not a loose connection. I am using a Nimble with Nimble adaptor mount with nut trap for the large nut that holds the heatsink I will try without it.
      I've tried sensitivities from 25:230 to 155:100
      https://www.youtube.com/watch?v=nwT9KuK1cSQ
      Have you seen others do this? I am trying to decide if I need to pull everything apart to look for a cause or not?
      www.precisionpiezo.co.uk
        I repaired a couple of strain effector boards with similar symptoms. The diagnosis was bad soldering of U1 or U3 to the PCB, but there are other potential causes.
        • DjDemonD
          I'll check those thanks.
