    Weird issue PanelDue. I think it has a bad SB diode. Ideas?
    PanelDue
    2.7k
    • ddt154undefined
      ddt154
      interesting - I discovered panel can receive data from Duet. Using WiFi/Web interface I did a print and noticed on the panel that it is getting print status. Ie Temperature readings. But yet on the Panel, it shows I have 4x extruders, but on DuetWiFi.. it is programmed for 1. I'm going to hit the pins with soldering iron.. We'll see if that makes a difference.
      -dt
        Another way to test data reception by the Duet is to use M117 or M300 commands.
        • ddt154undefined
          ddt154
          Status Update: fixed
          So hit the R4 and R5 2k2 resistors, D3 sb diode, and output pins with soldering iron. Worked for awhile and then stopped transmitting again, like before. I then removed these resistors and diode and then bridged over where the 2k2 resistors were and voila, PanelDue is working.
          So I tested the 2k2 resistors and they are ok, however SB diode seems to be the culprit in this case.
          I'll keep you posted if this arises again.
          Many thanks for your help
          -Drew
