Config.g deleted when saved in Duet Web Control
  • I hunted the forum for something similar to this issue without luck.
    Every time I edit the config.g file and save, it is deleted and replaced with a config.g.bak file. The error I get is "Update file size is different (4624 vs expected 3164 bytes)".
    This even happens when I just save without changing anything.
    Firmware version is 1.19.2. DWC version 1.2.
    Any help appreciated.
  • Sorry, updated firmware 1.2. problem fixed.
    I'm glad you solved it. I'm guessing that there is an incompatibility between DWC 1.20 and RRF 1.19.
