Manual Bed correction
Hi!
I did the following
in file bed.g
[c]
G30 X10 Y180 Z-99999
G30 X180 Y180 Z-99999
G30 X100 Y10 Z-99999 S3
[/c]Then I call the G32 command.
The head is positioned above the set point. A standard window appears.
I make a correction with a sheet of paper and press OK.
I do this 3 times.
I start an dummy print and see that the correction received does not apply.
How to correct the curvature of the bed by hand?
Thanks.
; Sorry for my English. -
You can't measure curvature of a bed using just 3 probe points, all you can do is work out much it is tilting in two directions. You need at least 4 point to measure curvature if it is the same in both directions (think of the surface of a sphere), or 5 points if the curvature is different in different directions like an ellipsoid.
The example shows 3 points.
OK.
Command G32 with what parameters to cause for saving of result (in ROM or file)? -
G32 probing results are not saved when you turn the power off. If what you are trying to achieve is bed level compensation, then you should use G29 mesh bed probing instead.
Share an example? I have a concave bed in the middle((
See https://duet3d.com/wiki/Using_mesh_bed_compensation. If you are not using G32 and the bed.g file for anything else (e.g. delta calibration, auto bed levelling using multiple leadscrews, or the manual bed levelling assistant), you can put the G29 command in bed.g if you wish instead of G30 commands.
