    Interface with SX1509
    • Algadz
      Algadz last edited by
      Hi everyone,
      I need some additionnal output so I'm trying to use the Sparkfun SX1509 i2c extension board.
      My setup (M115 call) : 1.21RC1 ELECTRONICS: Duet Ethernet 1.02 or later + SX1509B expander FIRMWARE_DATE: 2018-01-25
      I have soldered the sx1509 to be at i2c address 0x71 (I've checked with my Raspberry Pi that the address is correct).
      My problem is the following:
      I tryed to use the M42 S255 P1 command to set sx1509 pin 15 to HIGH,
      and the board answer is : "Logical pin 255 is not available for writing" (same problem for pin 220 to 235)
      Is there any thing to do to set this pin to output mode ?
      I've tryed using :
      M260 A0X0E B0X00
      M260 A0X0F B0X00
      to set RegDir register of the sx1509 to set pin 0 to 15 to output mode but the problem remain
      I've also tried to send :
      M260 A0X10 B0XFF
      M260 A0X11 B0XFF
      to set RegData register and set pin 0 to 15 to HIGH but no result either.
      Thank you 🙂
      Alban
      • Algadz
        Also for the wiring of the sx1509, I plugged it to the following pin of the expansion header of the Duet Ethernet
        SX1509 DUET
        SCL –--> TWCK0
        SDA ----> TWD0
          The logical pin numbers you need to use in the M42 command are 120 to 135.
          • Algadz
            Thanks it works !
            You might have to correct the port value in the wiki here (?) :
            https://duet3d.com/wiki/Adding_additional_output_ports
            Alban
              Done.
