Laser Support
does the duet wifi support a laser
i would like too integrate a laser into a 1 nozzle 3d printer for engraving
Several people have used Duets for laser engraving, using the M571 command to turn the laser on when the GCode indicates that extrusion should take place. I am aware that some other firmwares use different techniques and different GCodes, but I am not aware of anything that might be considered a standard in this area.
ok if i get it working i will let you know.
