    Z-probe (bltouch) releases too early when doing G29 mesh leveling
    • Asdasd1234
      Asdasd1234 last edited by
      Hi all,
      My z-probe works fine when doing a single point homing, but when I do the mesh bed, the pin triggers at the right point, but releases nearly instantly and hits the bed before the bed has a chance to move away.
      Am I missing something?
      Thanks
      EDIT
      another question aswell… The x-y offsets on g31.. if I have y10, does that mean that when the nozzle is at y0, the probe is sitting on y10, or the other way round?
      many thanks again!
        1. I am aware that some users have this problem with the bltouch and clones. Using a higher travel speed (to increase the speed at which it moves up) works for some users. I may change the behaviour in the next firmware release.
        2. Z probe offset of Y10 means that the probe is over the bed at Y10 when the nozzle is at Y0.
        • Asdasd1234
          Thanks!
          This one is a genuine bltouch now after I broke the original clone (drove it sideways and bent it off on the bed 😞 ).
          Increasing the speed isn't possible unfortunately as i'd need to increase it by 5x the amount to escape the falling pin. I have a corexy with a heavy bed so although 2x is do-able, I wont be able to outpace the sensor.
          Can I suggest maybe a "z-probe reset delay" or something where you could have the pin wait 1 second before dropping again.
          Currently, I think it's only a matter of time before the pin drops early enough that it bounces back up and fails
          • coolice
            coolice last edited by
            Subscribed as I see the same quirk with mesh bed levelling.
            I drop the bed 40mm and then initiate the mesh levelling, which sees it get to the first point without clipping the bed.
