PanelDue No Nozzle Icon…
Hi there.
I just building my first Delta and confused about nozzle icon…I have just 1 tool with 1 heater...In DWC all good, only bed and 1 tool, but PanelDue show to me one more wrong nozzle....
Firmware Version: 1.20 (2017-12-23)
WiFi Server Version: 1.20
Web Interface Version: 1.20
PanelDue 1.20b1Can someone help me?
This my config
M111 S0 ; Debugging off
G21 ; Work in millimetres
; Automatic saving after power loss is not enabled;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
M665 R234.295 L467 B197.5 H471.807 X-0.272 Y-0.589 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0.463 Y0.075 Z-0.538 ; Put your endstop adjustments here, or let auto calibration find them
M208 Z0.1 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops
M558 P1 X0 Y0 Z0 F150 H10 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
G31 P500 X15 Y15 Z1.303 ; Set Z probe trigger value, offset and trigger height
M557 R165 S20 ; Define mesh grid
M581 T1 E0 S0 ; Endstop E0 Pause; Drives
M569 P4 S1 ; Drive 4 goes forwards
M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
M92 X160 Y160 Z160 E879:879 ; Set steps per mm
M566 X800 Y800 Z800 E800 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
M906 X2000 Y2000 Z2000 E800 I10 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M572 D1 S0.1 ; Pressure advance
M915 P0:1:2 S10 F1 H400 R1 ; Stall detection, R1 - log, R2 - pause; Heaters
M305 P0 T100000 B3950 R4700 H30 L0 ; Set thermistor + ADC parameters for bed thermistor
M305 P2 X201 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 201
M143 H2 S280 ; Set temperature limit for heater 1 to 280C
M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds; Tools
M563 P1 D1 H2 S"One" F0 ; Define tool 1
G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C; Network
M550 PMyDelta ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P0 H2 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S0 I0 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S0 I0 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Custom settings are not configured
T1
M911 S21.0 R23.0 P"G91 M83 G1 Z5 E-5 F1000" ; auto-pause
M912 P0 S-0.3 ; CPU temp correct
M501 ; Read stored parameters config-override.gThank you )
The current PanelDue firmware expects the tools to be numbered from zero, the same as most slicers do.
Hmm, I changed 2 lines:
M563 P0 D1 H2 S "One" F0
G10 P0 X0 Y0 Z0 R0 S0Nothing….just 1 icon are showed now..
Can I fix it in the firmware?
Omg…nothing do not understand....
I plugged all in E0 (heater, motor) and PT100 to U1 (RID1)...why duet still show me second tool?; Heaters
M305 P1 X200 ; Set thermistor + ADC parameters for heater 0 and remap it to channel 201
M143 H1 S280 ; Set temperature limit for heater 0 to 280C
M563 P0 D0 H1 S"One" F0 ; Define tool 0
G10 P0 X0 Y0 Z0 R0 S0 ; Set tool 0 axis offsets, active and standby temperatures to 0Cwhat is wrong?
Are you using heater 2 for something?
Ouh, just now switched power off to on and all gone well. Before I try to restart by DWC..not manual off power.
Thank's )
The firmware seems to think you have tool 2 configured for something, because it is telling PanelDue that you have 3 heaters in use. Please post your current config.g file.
