    Endstops on expansion connector not working
    1.1k
    • wackyfrogundefined
      wackyfrog
      Hi!
      I'm trying to get work any of endstop pins on expansion connector. I've connected GND (pin2) and E2_STOP (pin4) to normaly closed emergency stop button. Put in config.g M581 E0:6 S1 C0 T0, restarted board. But nothing happens when I pushing and releasing the button. I tried to connect button to another slot pins (2+14, 2+24), no luck. But it works perfectly when connect to E0_STOP or E1_STOP.
      Duet Web Control at tab "machine properties" shows changing of status for drive's 0-4 endstops, but 5-9 always in status Endstop hit No, 10-11 - yes.
      Firmware Name: RepRapFirmware for Duet WiFi
      Firmware Electronics: Duet WiFi 1.0
      Firmware Version: 1.20 (2017-12-23)
      WiFi Server Version: 1.20
      Web Interface Version: 1.20
      Thanks for help.
      config.g:
      ; generated by RepRapFirmware Configuration Tool on Tue Feb 13 2018 20:09:36 GMT+0200 (EET)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X0 Y0 Z-207 S1 ; Set axis minima
      M208 X212 Y117 Z0 S0 ; Set axis maxima
      M574 X1 Y2 Z2 S0 ; Set active low endstops
      M558 P0 H0 F120 T3600 ; Set Z probe type to switch and the dive height + speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20 ; Define mesh grid
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X400 Y400 Z400 E420 ; Set steps per mm
      M203 X3000 Y3000 Z2400 E1200 ; Set maximum speeds (mm/min)
      M201 X50 Y50 Z50 E250 ; Set accelerations (mm/s^2)
      M906 X700 Y700 Z700 E1000 ; Set motor currents (mA)
      M84 S0 ; Disable motor idle current reduction
      M141 H2 ; Assign chamber heater to heater 0
      M301 H2 P-1 ; Set heater 2 to bang-bang mode
      M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
      M143 H2 S50 ; Set temperature limit for heater 2 to 50C
      M563 P0 D0 H1 ; Define tool 0
      M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H2 T30
      M581 E0:6 S1 C0 T0
      T0 ; Select first tool
        To use the endstop connections on the expansion connector, you need to use firmware 1.21RC1 or later.
          wackyfrog
          Thank you for answer, dc42
          I've updated firmware:
          Firmware Version: 1.21RC1 (2018-01-25)
          WiFi Server Version: 1.21RC1
          Endstop now displays inverted (Machine properties->Drive Configuration).
          The state changes to "No" when endstop is touched (home position, led is on now on duet board).
          See screenshot
          Endstops 0-2 (x,y,z) on screenshot was activated (shorted to gnd, home position); E0 & E1 not connected at all. Previous fw (v1.20 duet & v1.20 web server) displayed "Yes" in the same situation for 0-2 and "No" for 3,4.
          And about endstops on expansion conn – nothing changed after fw update, trigger not working, state not changes at tab "machine properties").
            Do you still have S0 in your M574 command, or have you changed it?
            It's normal for E0 and E1 to show as triggered when nothing is connected to them and they have no corresponding axes, because in the absence of a M574 command to configure them (which you can only do if you have another 2 axes) they default to active high.
              wackyfrog
              @dc42:
              M574 X1 Y2 Z2 S0
              @dc42:
              Sometimes I see drive 8 endstop state randomly changes. Tried to pull-up Epin_STOP with 10k to 3.3v, tried different pins, tried to connect STOP pin directly to to GND, state not changes.
              I flashed fw 1.20 again:
              In same conditions, just after update "Machine properties" – see screenshot
                I am sorry, the pin assignments for the expansion connector endstop inputs are wrong in the 1.21RC1 firmware. Please try 1.21RC2 which I hope to release later today.
                  wackyfrog
                  Thank you!
                  I've updated to 1.21RC2, endstops on expansion connector works well.
                  But there area strange behavior. The button (normally closed) connected to E2 pin.
                  M581 E0:6 S1 C0 T0 – trigger for E2 does not work
                  M581 E2 S1 C0 T0 – trigger for E2 pin works well
                    Command M581 E2 S1 C0 T0 is the correct command for setting up a trigger on the E2 endstop input. Why were you expecting M581 E0:6 S1 C0 T0 to have anything to do with the E2 pin?
                      wackyfrog
                      On the basis of the documentation https://duet3d.com/wiki/G-code#M581:_Configure_external_trigger
                      Example
                      M581 E1:2 S1 T2 C1 ; invoke trigger 2 when a rising edge is detected on the E1 or E2 endstop input and a file is being printed from SD card
                      I thought that E1:2 indicates a range in that example. What does symbol ":" exactly means in this command (M581) ?
                        Yes, it means exactly the numbers in the colon-separated list.
