    Heater Temp Falls down during print
    • jaydevdaveundefined
      jaydevdave
      Heater 1 model: gain 472.2, time constant 252.2, dead time 7.7, max PWM 1.00, mode: PID
      Computed PID parameters for setpoint change: P12.4, I0.049, D66.7
      Computed PID parameters for load change: P12.4, I0.588, D66.7
      24V 40W Heater
        https://duet3d.dozuki.com/Wiki/Spurious_heater_faults_and_how_to_avoid_them
          jaydevdave
          https://www.dropbox.com/s/5tmygl7doud4fum/01.png?dl=0
          what does this temp graph mean ?
          • EasyTargetundefined
            EasyTarget
            @jaydevdave:
            That the temperature is fluctuating?
            Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
            PrintPy2024 to the rescue!
            MicroPython based; with simple wiring and and no custom PCB.
              If the temperature shows regular oscillation while the hot end is heated but idle, increase the dead time (D parameter in the M307 command for that heater) slightly. If it only fluctuates when printing, that's normal if the fluctuations are small.
                EasyTarget
                Fitting a silicone sock to my heatblock stopped similar small variations I noticed, it's probably worth trying one (or kapton tape layers) to rule out stray drafts etc that can make temps wobble.
                And remember that PID is a feedback system; so it will wobble slightly in response to changing demands (say moving from a big area of constant rate wall/top printing to suddenly printing a lot of support with more travel than print moves), or moving from the cold side of the heatbed to the side out of the drafts, etc.
                Each time the load on the heatblock changes you will see a small fluctuation before the controller brings it back to stable, and tuning PID's is a compromise between getting the fastest possible response, but without overshooting and possible oscillating around the set temperature without stabilizing.
