    Cartistian boxed IDEX Printer (WIP)
    My Duet controlled machine
    1.3k
    • Phil_AEundefined
      Phil_AE
      Hello everybody,
      I started with 3d printing with an Anet A8, after some Modifications the Prints are quite good but i am running into trouble with the small print area.
      After looking around for the "perfect" printer for my needs (and budget), my needs:
      1. Printbed at least 500mmx500mm
      2. Multiextrusion ASA and PVA
      well thats basicly all i need but it turned out to be rather difficult to find or quite expensive, so i started to plan my own 3d printer.
      limitations:
      1. needs to fit through the door (max 75cm width)
      2. Budget 2500$ (might not get all features from the start)
      So i basicly started to built the printer the way i thought it would work out, after a couple of design changes thats the state it is currently in:
      overall size: L1050mm W720 H1000mm
      Z-Axis: 4linear rails MGN12+ 4x TR8*1 leadscrew, driven by an nema23 57HM51 (0.9°) stepper motor (or 2 if it is not enough)
      Y-Axis: 2linear rails MGN12+ 9mm GT2 belt (on both sides, connected with an 8mm rod), driven nema23 57HM51
      X-Axis: 2x 1linear rail MGN12+ 9mm GT2 belt, driven by nema 17 42HM40 (0.9°) stepper motor.
      the rails are on opposing sides of the 2020 extrusion so both can travel the complete length of the x-axis
      planed:
      Electronics: duetwifi+duex5+sensorboards+duepanel integrated and filamentsensors
      Heatbed: 6x 300x300mm 750Watt Siliconheater+ Standalone Controller for each heater
      heated Chamber: somehow i need to heat the chamber, i will see if the large heatbed is enoughto heat the chamber or if i have to add a seperate heater)
      Hotend: 2x e3d Chimera watercooled
      Extruder: 4x zesty Nimble
      I hope to have everything running around june
      PS: spools/steppermotors and electronics getting there one compartment on top of the printer
      I hope everything works out as i planned, exspecially the software, i am more an hardware guy, rather then a programmer…
      Phil
        The software won't be a problem, I'm here to help! But the hardware aspects of large printers are challenging.
        You don't need to use a standalone controller for the bed heater, just use an AC mains silicone heater controlled using a SSR. Details on the wiki. Likewise the chamber heater, if you need one.
        • Phil_AEundefined
          Phil_AE
          so built is starting to take shape, i currently ordering the missing pieces and doing some progress on the enclosure, the small stuff really adds up and there are always small thinks that i miss.
          Phil
          • Phil_AEundefined
            Phil_AE
            i just wanted to give a quick update, everything moves fine right now, but i could noch test ist because i dont have the tubing adapters for my chimera aqua and e3d keeps telling me it will be availible next week (for the last month)
            i dipped the idex and built a 2nd printer in the enclosure (420x420x300mm) to run the 2nd chimera aqua.
            Phil
