Dual extrusion help
Ive upgraded the tevo little monster with a duet wifi and chimera hotend form E3D everything seams to work so far but the extruder for the Left side extrudes almost 10X the filament called for. I extrude 1MM and it moves 9.02mm normally I'd go in and change the steps per mm and be done with it but I don't know what I'm doing and I used a downloaded config.g file from a group of people that have already converted the LittleMonster to the duet wifi I just took it a step further by adding dual extrusion to the upgrade. what do i need to do to tune the 2nd extruder here is the config.g
thanks in advance for the help
; Configuration file for Duet wifi (firmware version 1.17)
; generated by RepRapFirmware Configuration Tool on Mon May 22 2017 22:56:20 GMT-0400 (Eastern Daylight Time); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
M555 P1 ; Set firmware compatibility to look like RepRapFirmare
M665 R157 L397.1073 B175 H530 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
M208 Z-5 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Define active high microswitches
M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
M557 R130 S20 ; Define mesh grid; BL-Touch
M307 H3 A-1 C-1 D-1 ; reserve pin 21 for M42 or servo use
M558 P5 X0 Y0 Z1 H5 F100 T2000
G31 P25 X0 Y0 Z1.483 ; Set Z probe trigger value, offset and trigger height; Drives
M350 E32 I0 ; Configure microstepping without interpolation
M350 X32 Y32 Z32 I1 ; Configure microstepping with interpolation
M92 X160 Y160 Z160 E837 ; Set steps per mm
M566 X1200 Y1200 Z1200 E3000 ; Set maximum instantaneous speed changes (mm/min)
M203 X39960 Y39960 Z39960 E3000 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E1500 ; Set accelerations (mm/s^2)
M906 X1800 Y1800 Z1800 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S285 ; Set maximum heater temperature to 285C
M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
M305 P0 T100000 B4607 C8.950070e-8 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2; Tools
M563 P0 D0 H1 ; tool 0 uses extruder drive 0 and heater 1
G10 P0 S0 R0 X-8 Y-4 ; set tool 0 temperatures and offsets
M563 P1 D1 H2 F2 ; tool 1 uses extruder drive 1 and heater 2. Fan 2 is mapped to fan 0
G10 P1 S0 R0 X1 Y12 ; set tool 1 temperatures and offsets; Network
M550 PTEVO LITTLEMONSTER ; Set machine name
M551 P123 ; Set password
M552 S1 ; Enable network
M587 STEVO LM P"5333467696Aa" I192.168.1.180 J192.168.1.254 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off; Custom settings are not configured
M501 ; Load saved parameters from non-volatile memory -
Try changing these lines:
M350 E32 I0 ; Configure microstepping without interpolation ... M92 X160 Y160 Z160 E837 ; Set steps per mm
to:
M350 E32:32 I0 ; Configure microstepping without interpolation ... M92 X160 Y160 Z160 E837:837 ; Set steps per mm
I changed the lines and adjusted steps per MM and it works!!!!!!! thank you so much
