DWC shows two layer heights, when single height sent from S3D
  • undefined
    Hey_Allen
    As the title says, I'm scratching my head over an issue that I've noticed recently.
    On my printer, running 1.19 firmware, when I start a print and look at the print status, I see 0.1mm/0.3mm Layer Height in the print statistics.
    The print settings in Simplify 3D are for 0.3mm, with no variations.
    The only layer dependent setting I have configured is going from 0% part cooling fan to 50% fan when it advances to layer two.
    Does anyone have any idea what drives the detection of layer height, that is then displayed on the web interface?
    • undefined
      Please make your gcode file available.
      Do you have Z hop during travel moves enabled?
      • undefined
        Hey_Allen
        Z hop is not enabled, though I have been thinking to do so, after watching it gouge a couple of the lower layers.
        Here is the latest print, the back cover for a 4.3" PanelDue.
        https://drive.google.com/file/d/1468K6zyNd24ylvFO1e7aVCRXsA4gUHRY/view?usp=sharing
        • undefined
          Thanks. What I think is confusing it is the G1 Z0.1 command in your start GCode. If you change that to G1 Z0.3, or to G1 Z[first_layer_height] if that works in S3D, I think that will solve it.
          • undefined
            Hey_Allen
            I forgot that was even in there.
            That is a remnant of finding z-0 and trying to get the bed levelling to behave, and somehow ended up in the start codes instead of migrating into the config.g z-probe offset settings.
            • undefined
              Hey_Allen
              Okay, I tested this again with the S3D startup scripts no longer having the z movement preamble, after adjusting the config.g to reflect the probe height.
              It is still showing 0.1mm/0.3mm layer height, and I noticed that this current print completed on layer 43 of 75.
              "Layer: 43 of 75, Filament Usage: 5094.1mm of 5094.1mm (0.0mm remaining)"
              Sample g-code:
              https://drive.google.com/open?id=16V7LTbmVSWmawGIZLEn_tXuUV1qrGCa-
              Screenshot:
              https://drive.google.com/open?id=1Qa93VdHxQ88LMUK7JO33bPyFtUqV-707
              1 out of 6
