    How to remap default fan
    1459
    • deckingman
      deckingman last edited by
      Just started to play with my shiny new Duex5. My power supply is 24V and my existing print cooling fan (fan0) is 12v which I was running via a 24 to 12v DC converter. I can now make use of the 12V jumper on the duex5 and connect the 12v print cooling fan to one of these outputs - say fan 3. How do I remap this to be the default fan? That is to say that my slicer (Slic3R) controls print cooling by putting M106 S(nnn) commands in the gcode file without a fan number so it defaults to fan 0 and I need to change the default to be fan 3.
        See http://reprap.org/wiki/G-code#M563:_Define_or_remove_a_tool. Fan mapping only happens when a tool is active.
        • deckingman
          Thanks David. So if the print cooling fan is fan 3 and I add F0:3 to all of my tool definitions, then M106 commands will control that fan, but only when any one of the tools is active (as would be the case during a print). Is that correct?
            Not quite, you need just F3.
            • goury
              goury last edited by goury
              And now I too found myself having similar problem.
              My case was short circuit that led to damaging fan 0 somehow (now it outputs 2.3v when set to 100% and 5.5v when set to 0%, some weird magic smoke was involved for sure).
              I found my solution in adding F0:2 parameter to M106 command in config.g file.
              So now my fan is connected to fan 2 connector and everything is working as it was before this accident.
              I officially thank deckingman for creating well-indexed and googlable topic and dc42 for providing
              ad documenting nice solution.
              Thank you guys, you are the best!
              • DjDemonD
                DjDemonD last edited by DjDemonD
                Is there a way to remap a fan to a heater output, so if I want to use E1 heater connected to a fan/water pump rather than the P1 fan output? I would want to be able to thermostatically control it as I currently do with the P1 fan output. I am just concerned my fan and water pump combo might be a little too much for the fan output.
                I could implement an external mosfet on P1 fan, but might be nice to know in case I need to do it later?
                  dc42 administrators @DjDemonD last edited by
                  @djdemond said in How to remap default fan:
                  Currently no, but I plan to add this facility in a future firmware release, perhaps 2.02.
                  • DjDemonD
                    That would be good. I had my pump and fan stop working yesterday and presumed I might have overloaded the P1 fan output, but as usual just a loose connection.
