    Z height strangeness
    • Drammyundefined
      Drammy
      Hi all,
      Fairly new to 3d printing and certainly new to the Duet Wifi.
      Have got a problem where I (manually) level my bed as I have no IR probe and when I got to print always starts about 0.2mm below the freshly levelled z0.
      I don't understand why I can home everything, level the bed on multiple positions and then when it comes to printing the print starts at a completely different z height.
      How can it go lower than z0 as set by my Z end stop (two wire close/open switch)?
      And why is it doing it??
      EDIT:
      I have no z offset in the GCode of my slicer (Simplify 3D)
      My end stop set up is as follows:
      [[language]]
      M574 X1 Y1 Z1 S0                                                               ; Set active low endstops
      M558 P0 H5 F120 T6000                                                          ; Set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z0                                                              ; Set Z probe trigger value, offset and trigger height
      M557 X25:175 Y25:175 S20                                                       ; Define mesh grid
      Note: G31 was set as
      G31 P500 X0 Y0 Z2.5
      so I changed it to 0 with no difference.
      Should I have increased it instead?
        Please post the contents of your homez.g and homeall.g files.
        • Drammyundefined
          Drammy
          Here's homez.g
          [[language]]
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool on Mon Mar 05 2018 14:15:11 GMT+0000 (GMT)
          G91               ; relative positioning
          G1 Z5 F6000       ; lift Z relative to current position
          G1 S1 Z-185 F1800 ; move Z down until the switch triggers
          G92 Z2.5           ; set Z position to trigger height
          ;G91              ; relative positioning
          ;G1 Z5 F100       ; lift Z relative to current position
          ;G90              ; absolute positioning
          And here's homeall.g
          [[language]]
          ; homeall.g
          ; called to home all axes
          G1 S1 X-205 Y-205 F4800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 X5 Y5 F6000          ; go back a few mm
          G1 S1 X-205 Y-205 F360  ; move slowly to X and Y axis endstops once more (second pass)
          G1 S1 Z-185 F1800 S1    ; move Z down stopping at the endstop
          G92 Z2.5                ; set new Z position
          ;G1 Z5 F100             ; uncomment this line to lift the nozzle after homing
          I'm guessing the problem is those G92 commands?
          Should they be set to 0 then?
          If so, I'm curious why the riprap configure tool sets this as default. Especially when it clearly seemed to understand that I had a z end stop switch only and no probe.
          Surely it would have been better for it to default to 0 and not wreck peoples beds 😞
          • Drammyundefined
            Drammy
            OK, so I've altered the home files' G92 commands to Z0 and it has worked well. Phew!
            @dc42: thanks for pointing me in the right direction. (great board btw)
